| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
Hi all, I've just configured EMC2 for use with my homebrew engraver/mill. I'm really pleased with the way it went, pretty much hitch free (once I'd read the manual ). Much nicer than the TurboCNC I'd been using previously.The machine has only a small Z movement. I've configured the axis to home to a switch at +15mm. Most of the time, pressing 'home', winds the Z axis up to the switch then up/down before reseting the machine position display to 15.000 (exactly as expected). However after I've run an air cut, zeroed the axes with g00 x0 y0 z0, then press home all (or Z only) it'll home up to the switch jiggle (at about 15mm) then reset the display to 14.300. I don't think the Z axis is losing steps (and in any case the home should reset to 15.000 every time shouldn't it?) Any ideas? Oh and while have your attention; How do you get EMC to start full screen? (I'm a linux newbie) |
Can't think of the answer to the homing question. Maybe after some coffee. Interesting looking machine. If that's a homebrew you have some obvious fabricating skills. I love homebrews.
__________________ Anyone who says "It only goes together one way" has no imagination. |
| Bill if you are doing an offset and not resetting it after like in the MDI window EMC is correctly reporting your offset position after the home. Just do a G92.1 to clear the offsets and reset the variables to 0. http://www.linuxcnc.org/docview/html...,-G92.1,-G92.2, John |
| Devils pie indeed ![]() It's bad enough that the computer world is filled with jargon, but when Linux developers use stupid names for applications etc. they shoot themselves squarely in the foot. It simply puts me (and many other people) off the idea of using the operating system ![]() Alt-F10 is is then :LOL:
It's been in development for a decade. Most of it is parts recycled from other machines. I had only an old delta pillar drill when I started it, so I had to re-use any precision parts I could find (e.g. the lead-screw bearing blocks are cut from the end plates an 8" FDD drive motor). Last edited by BillTodd; 08-26-2008 at 02:58 PM. |
Thanks John. It wasn't actually offsets, but your post did remind me to check and edit the tool table. ops:I didn't realise EMC had a default set of tools, one being 0.7mm long! |
| EZ-TRAK SX II homing problem HELP! | guitarist1904sd | Bridgeport and Hardinge Mills | 5 | 08-04-2008 09:08 PM |
| Just another homing problem | jeffrey001 | DIY-CNC Router Table Machines | 2 | 05-31-2008 07:18 PM |
| Homing problem in mach2 | atifeh | Machines running Mach Software | 7 | 12-19-2006 07:25 PM |
| Problem With Homing X Axis | elalto | Mach Software (ArtSoft software) | 1 | 09-15-2006 07:28 PM |
| Homing Problem V4.0.1 | BMaynard | TurboCNC | 5 | 04-13-2006 01:22 AM |
