Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 08-10-2008, 09:00 PM
DrStein99's Avatar
DrStein99 is on a distinguished road
2 Parallel ports
I'm trying to get started with EMC2 from the cd-install. I have setup many CNC machines in the past using MACH-3 (Windows); so I am very familiar with the technology; but need some help with EMC2.
I ran the "stepper setup wizard". Looks like the first page prompts me for a "PARPORT BASE ADDRESS". My unit has two paralell ports. How / where do I go to configure that?
-Erich Stein
WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
Old 08-10-2008, 11:03 PM
acondit's Avatar
acondit is on a distinguished road
You can only configure one port with the step config wizard. Then you will have to edit the config files to add the second port.
Alan
http://www.alansmachineworks.com
Old 08-17-2008, 06:47 AM
Big John T is on a distinguished road
Usually the default base address that stepconf suggests will work.
There is a lot of info on the wiki site on hooking up second parallel ports. One that I know of is at
http://wiki.linuxcnc.org/cgi-bin/emc..._A_MPG_Pendant
John
Old 09-29-2008, 08:47 PM
stratcat50 is on a distinguished road
Open a terminal and run a 'lspci -v'. This will give you a list of all PCI devices including the addon port
Look through the listing and find the port and its address. It's usually pretty obvious.
Then edit your hal file and look for lines like
loadrt probe_parport
loadrt hal_parport cfg="0x0378 out"
If you've got a semi-working config, that will be the address of parport.0.
Put the address of the 2nd port after the first, inside the quotes. It is then parport.1.
Depending on your usage, you might have to use the 'in' or 'out' parameters. Mine looks like:
loadrt hal_parport cfg="0x0378 out 0xd800 in" and is used for switches & sensors.
Good luck!
Old 09-30-2008, 04:06 PM
DrStein99's Avatar
Ok so EACH paralell port must only be assigned INPUT or OUTPUT yes? I am trying to read the documents which are really overwhelming and filled with fluff - I really dont think I need to understand how to generate a sine-wave as my first practice in understanding the hal. Just tieing pins on a paralell port to step/direction w/ digital inputs is a nice start.
-Erich
Old 09-30-2008, 04:35 PM
You need to skip down to this part of the manual for paraport info...
http://www.linuxcnc.org/docview/html...ml#sec:Parport
John
Old 10-05-2008, 08:54 PM
DrStein99's Avatar
Got it now, thanks for that. The HAL appears to be a nice elaborate module itself, it seems its made that someone could code their own API interface to control the HAL directly. Very interesting and distracting when I am trying to assign the ports and pins in my hardware to the EMC2 program.
-Erich
Old 08-10-2010, 03:34 AM
tyo tyo is offline
tyo is on a distinguished road
a use second parport is mean we use two of parallel system???
and...
the address 0xd800 have some pin 10,11,12,13,15 at same parallel output 0x378..???
Old 08-10-2010, 08:41 AM
wendtmk's Avatar
Moderator
wendtmk is on a distinguished road
tyo,
No - two parallel ports, typically two different signal paths. You may be able to get identical signals,one on each port by using HAL, but normally you would use the second parallel port to carry different signals, say for a pendant, or simply to allow more drivers (axes) to be used.
Is that what you were asking?
Mark
Old 08-11-2010, 04:00 AM
tyo tyo is offline
so..what the address we can use for same parallel with 0x378..??
actually port input at standard LPT-1...
i'm confused with homing input...for limiting approx...
help me please....
Old 08-11-2010, 08:56 AM
wendtmk's Avatar
Moderator
help me please....
Not quite sure what exactly you are trying to do. If you install a second parallel port, it will have a different address. Usually assigned by your computer BIOS. Depending on what operating system you run, there are different ways of finding out what the address is. LPT1 is usually 0x378.
Everything you ever wanted or needed to know about parallel ports:
http://www.beyondlogic.org/spp/parallel.htm
Mark
  #12   Ban this user!
Old 08-12-2010, 03:19 AM
tyo tyo is offline
LPT-1 have three access of port.
there are.
1. "data" the address is 0x378 => pin 0 till 9 (output)
2. "status" the address is 0x379 => pin 10,11,12,13,15 (input)
3. "control" the address is 0x37a => pin 1,14,16,17 (output)
and the other is ground..18 till 25
how to configure EMC for same parallel (LPT-1) be able input at (379) and output at (378)...???
i've trying change the script on .HAL:
loadrt hal_parport cfg="0x378 out 0x379 in"
but still doesn't work...
More on ports and pins andrewbishop66 Mach Software (ArtSoft software) 2 03-08-2007 07:05 PM
SPC Ports What are your Use? SMW Precision Calibration & Measurement 1 07-31-2006 03:46 PM
ports and pins planescott Stepper Motors and Drives 5 03-24-2006 11:57 PM
Parallel ports itsme Computers and Networking 8 09-30-2005 08:20 PM
3.3 V vs. 5 V TTL on parallel ports HansM Machine Problems, Solutions , Wireless DNC, serial port 4 07-28-2005 02:28 PM
