| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
I hate to put this post up, but I need help. I am new to linux EMC, not new to linux. I have been unable to get linux emc to drive a stepper motor. My computer is an AMd dual core. I am using the parallel port to drive a microkinetics stepper motor drive(DM4050) which is connected to a Superior Electric Stepper motor. I have tested the drivers and motor w a galil motion controller and the motor turned fine. I have pin 2 of the par port configured as step and pin 3 configured as direction. Any debugging help would be greatly appreciated. The Par port is a pci par port. |
| did you find the address of the pci printer port in linux? You will then need to modify your hal file similar to this...
| Still nothing. The Parallel card is a Siig serial/parallel. it showed up as irq 10, 9800[size 8] i/o ports ar 9800[size =8] i/o ports ar 9400[size =8] i/o ports ar 9000[size =4] I tried all addresses and nothing. ...I am wondering if linux doesn't like this card? |
| Alan
__________________ http://www.alansmachineworks.com |
| Hal file # Generated by stepconf at Thu Jul 24 08:17:55 2008 # If you make changes to this file, they will be # overwritten when you run stepconf again loadrt trivkins loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD traj_period_nsec=[EMCMOT]SERVO_PERIOD key=[EMCMOT]SHMEM_KEY num_joints=[TRAJ]AXES loadrt probe_parport loadrt hal_parport cfg=0x9800 setp parport.0.reset-time 10000 loadrt stepgen step_type=0,0,0 loadrt pwmgen output_type=0 addf parport.0.read base-thread addf stepgen.make-pulses base-thread addf pwmgen.make-pulses base-thread addf parport.0.write base-thread addf parport.0.reset base-thread addf stepgen.capture-position servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf stepgen.update-freq servo-thread addf pwmgen.update servo-thread net spindle-cmd <= motion.spindle-speed-out => pwmgen.0.value net spindle-enable <= motion.spindle-on => pwmgen.0.enable net spindle-pwm <= pwmgen.0.pwm setp pwmgen.0.pwm-freq 100.0 setp pwmgen.0.scale 1166.66666667 setp pwmgen.0.offset 0.114285714286 setp pwmgen.0.dither-pwm true net spindle-cw <= motion.spindle-forward net estop-out => parport.0.pin-01-out net xstep => parport.0.pin-02-out setp parport.0.pin-02-out-reset 1 net xdir => parport.0.pin-03-out net ystep => parport.0.pin-04-out setp parport.0.pin-04-out-reset 1 net ydir => parport.0.pin-05-out net zstep => parport.0.pin-06-out setp parport.0.pin-06-out-reset 1 net zdir => parport.0.pin-07-out net astep => parport.0.pin-08-out setp parport.0.pin-08-out-reset 1 net adir => parport.0.pin-09-out net spindle-cw => parport.0.pin-14-out net spindle-pwm => parport.0.pin-16-out setp stepgen.0.position-scale [AXIS_0]SCALE setp stepgen.0.steplen 1 setp stepgen.0.stepspace 0 setp stepgen.0.dirhold 60000 setp stepgen.0.dirsetup 60000 setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb net xstep <= stepgen.0.step net xdir <= stepgen.0.dir net xenable axis.0.amp-enable-out => stepgen.0.enable setp stepgen.1.position-scale [AXIS_1]SCALE setp stepgen.1.steplen 1 setp stepgen.1.stepspace 0 setp stepgen.1.dirhold 60000 setp stepgen.1.dirsetup 60000 setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb net ystep <= stepgen.1.step net ydir <= stepgen.1.dir net yenable axis.1.amp-enable-out => stepgen.1.enable setp stepgen.2.position-scale [AXIS_2]SCALE setp stepgen.2.steplen 1 setp stepgen.2.stepspace 0 setp stepgen.2.dirhold 60000 setp stepgen.2.dirsetup 60000 setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb net zstep <= stepgen.2.step net zdir <= stepgen.2.dir net zenable axis.2.amp-enable-out => stepgen.2.enable net estop-out <= iocontrol.0.user-enable-out net estop-out => iocontrol.0.emc-enable-in loadusr -W hal_manualtoolchange net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared ini file # Generated by stepconf at Thu Jul 24 08:17:55 2008 # If you make changes to this file, they will be # overwritten when you run stepconf again [EMC] MACHINE = jimtest1 NML_FILE = emc.nml DEBUG = 0 [DISPLAY] DISPLAY = axis POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL MAX_FEED_OVERRIDE = 1.2 INTRO_GRAPHIC = emc2.gif INTRO_TIME = 5 PROGRAM_PREFIX = /home/jim/emc2/nc_files INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in [TASK] TASK = milltask CYCLE_TIME = 0.010 [RS274NGC] PARAMETER_FILE = emc.var [EMCMOT] EMCMOT = motmod SHMEM_KEY = 111 COMM_TIMEOUT = 1.0 COMM_WAIT = 0.010 BASE_PERIOD = 100000 SERVO_PERIOD = 1000000 [HAL] HALFILE = jimtest1.hal HALFILE = custom.hal POSTGUI_HALFILE = custom_postgui.hal [TRAJ] AXES = 3 COORDINATES = X Y Z LINEAR_UNITS = inch ANGULAR_UNITS = degree CYCLE_TIME = 0.010 DEFAULT_VELOCITY = 0.10 MAX_LINEAR_VELOCITY = 1.00 [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl [AXIS_0] TYPE = LINEAR HOME = 0.0 MAX_VELOCITY = 1.0 MAX_ACCELERATION = 30.0 STEPGEN_MAXACCEL = 31.5 SCALE = 4000.0 FERROR = 0.05 MIN_FERROR = 0.01 MIN_LIMIT = -0.01 MAX_LIMIT = 40.0 HOME_OFFSET = 0.0 [AXIS_1] TYPE = LINEAR HOME = 0.0 MAX_VELOCITY = 1.0 MAX_ACCELERATION = 30.0 STEPGEN_MAXACCEL = 31.5 SCALE = 8000.0 FERROR = 0.05 MIN_FERROR = 0.01 MIN_LIMIT = -0.01 MAX_LIMIT = 40.0 HOME_OFFSET = 0.0 [AXIS_2] TYPE = LINEAR HOME = 0.0 MAX_VELOCITY = 1.0 MAX_ACCELERATION = 30.0 STEPGEN_MAXACCEL = 31.5 SCALE = 8000.0 FERROR = 0.05 MIN_FERROR = 0.01 MIN_LIMIT = -10.0 MAX_LIMIT = 10.0 HOME_OFFSET = 0.0 |
| HTEngrave, I would think that the 9800 is the right port. The only thing that looked really suspicious to me was the 60000 for dirhold and dirsetup. I am running an old Superior Electric drive and it requires 25000 dirhold and dirsetup (and I thought it was bad). So let me ask you a series of questions to see if we can figure this out. First, does it even spin the motors in stepconf? Do you have an actual estop switch? If so, when you push the switch do you see a change in the axis gui? What are you using for a BOB? Do you have anything wired to /HOME and /FAULT on the drives? Have you measured the +5v to the drive? Is the power LED on the drive coming on? Alan
| ...here are my answers First, does it even spin the motors in stepconf? ...Just working w one motor now, it does not spin when I am in stepconf Do you have an actual estop switch? If so, when you push the switch do you see a change in the axis gui? I do not have an estop switch. I have not playd much w the graphics, but yes it does change when I press the estop button. I am able to "jog" the x axis, the pointer on the screen moves, but no motor activity. What are you using for a BOB? ...sorry I don't know what a BOB is Do you have anything wired to /HOME and /FAULT on the drives? ...nothing wired to home or fault Have you measured the +5v to the drive? ...if you mean to the dm4050 yes, 5.06 to the logic side, 33.6V to the Vmm on the motor side. the motor is a 3.36V , 2.9amp motor. I have driven the motors w these drivers using a galil controler Is the power LED on the drive coming on? yes I am going to have a basic 3 axis machine, wanted to get one motor working before moving on. One thing I find a bit odd is that the Driver(Microkinetics DM4050) says it has a Min pulse width is 50us. If my math is right, I think that should be 50000ns. I tried that, but it made no difference. |
#10
| http://wiki.linuxcnc.org/cgi-bin/emc...l_Port_Outputs John |
#11
http://wiki.linuxcnc.org/cgi-bin/emc...r_Drive_Timing John |
#12
| ok...I just learned something about breakout boards and Parallel ports. my BOB is just a db25 connector soldered to a pcb w some terminal screws. After doing some reading, I learned that the output of todays parallel ports is 3.3V, not 5V ttl. This very well could be my problem because my drivers want 5V ttl. Going to get a opt isolate breakout board that has output levels to drivers at 5V ttl. I think that's a good place to start. I think the question was asked earlier, but I didn't quite understand. Will get back when I get a BOB. many thanks for eveyone's input. |
| Problem- SX3 Spindle Motor Wont Turn ON | ddexd | Benchtop Machines | 5 | 02-07-2008 06:30 AM |
| PICstep, motor won't turn | Mister H | PicStep Controllers | 35 | 01-07-2008 12:25 AM |
| mill/turn on a cin turn | Robert Timby | General Metal Working Machines | 4 | 01-31-2007 10:33 PM |
| Cin Turn turn/mill | Robert Timby | General CNC (Mill and Lathe) Control Software (NC) | 0 | 01-24-2007 07:12 PM |
| motor won't turn | anthony | Gecko Drives | 2 | 05-14-2005 12:55 AM |
