Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 07-16-2008, 10:21 AM
SpeedsCustom's Avatar
SpeedsCustom is on a distinguished road
Emc2 and Gecko Drivers, will it work?
I have a Taig CNC machine and am upgrading my drivers soon. I have been looking around and everyone recommends Gecko with my current stepper motors.
Someone had mentioned too me that I would be one of the first users too use EMC with Gecko drivers. What are the problems that may arise? I really would like too use EMC still, I love the program and have been using it for about 7 months.
Will I run into problems using Gecko's on my machine trying too run my Taig machine?
-Jason
Old 07-16-2008, 10:32 AM
samco is on a distinguished road
You are not the first person - by a long shot..
It will be fine.
http://wiki.linuxcnc.org/cgi-bin/emc...r_Drive_Timing
sam
Old 07-16-2008, 11:53 AM
Big John T is on a distinguished road
Gecko is one of the smoothest running drives and works well with EMC. There are thousands of Geckos being run with EMC. I'm using the G203v drives with my plasma cutter and would not use anything else with steppers. They are well worth the money. If you drive a tank over your Gecko drive and return it they will replace it free! The 203v has the shortest timing requirements so you can get the most speed from them with software step generation. They also morph from 10 microsteps at slow speed to single steps at high speed that way you get the best performance at any speed. There is a new drive coming out that is a lower voltage and much lower cost so if your limited to < 50v for some reason I would wait a week or three for them...
John
Old 07-16-2008, 12:34 PM
ger21's Avatar
He said you'd be one of the first with the new Gecko 540's.
Old 07-16-2008, 01:09 PM
That makes sense.. Still - should not be a problem
Old 07-16-2008, 01:51 PM
Only if he is first in line
AFAIK the 540 is a 4 axis scaled down 203v with DB connectors and a parallel port connector for $299... Can it get any easier?
John
Old 07-16-2008, 07:27 PM
cyclestart is on a distinguished road
Does this mean you're buying?
The "someone" was me. If you've read about the grief speedscustom has had with other drives my concern might maker more sense. This includes a couple of Xylotex drives. Xylotex are a low end drive but have given good service on my machine. Even though he gave a heroic effort and got a lot of good intentioned advice they just wouldn't perform for him. Knowing another emc user is setting up with the G540 makes the decision easier.
I also intend to try the G540. Will probably wait till they hit the resellers shelves and some feedback starts to come in. I'm more of a follower than trailblazer.
Anyone who says "It only goes together one way" has no imagination.
Old 07-16-2008, 08:57 PM
Cyclestart- I will have a huge review on the 540's. While I'm waiting for them too be released. I started stripping down the machine for cleaning and lubing and maintenance
I may also try the leadscrew conversion. Something I have been thinking about.
I think it was the xylotex system and stepper combination. I had it wired in a way that wasn't the best, but thought it was the only way without frying the board.
I look forward too the better Geckos.
You will be seeing work from me in the Benchtop forum, keep an eye out
-Jason
Old 07-17-2008, 08:43 AM
If I had an application for one I would buy the 540.
John
Old 07-17-2008, 09:02 AM
I'm buying them
It's nice that you get that 4th axis too! Could maybe finally put an indexer on or something.
-Jason
  #11   Ban this user!
Old 09-16-2008, 06:14 AM
Fixittt is on a distinguished road
I too ordered the g540 to og on my minitech minimill 2. I am also looking at emc2 for control. So it maybe a collaboration effort to get these 2 machines up and running. I am getting the machine ready for the new drive. granted I will be underpowered with the 24v xylotex power supply. But I will upgrade that at a later date. but my maxnc runs rock solid with the 24v xylotex (AFTER FIGHTING IT FOR YEARS) so It should be a nice upgrade.
Email says my g540 has been shipped.
  #12   Ban this user!
Old 09-16-2008, 08:49 AM
Fixittt, When you get ready for EMC2 check out the stepconf wizard to get your mill set up real fast. Check out the Getting Started Guide on this page to get EMC2 and get you up and running.
http://www.linuxcnc.org/content/view/5/5/lang,en/
John
Newbie- New Gecko drive and EMC2 waltm LinuxCNC (formerly EMC2) 2 02-06-2008 10:51 AM
(Gecko Drivers) Would you use ... DeekStarr Polls 15 01-16-2008 09:27 AM
Will a gecko G340 work with my servo? pimpbike Gecko Drives 3 11-28-2007 06:23 PM
will mach3 work with gecko drives derkiow Gecko Drives 11 11-15-2006 01:29 PM
To Gecko, or not to Gecko...that is the question! samualt Gecko Drives 11 09-22-2003 08:42 PM
