Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 06-23-2008, 08:07 AM
perezmu is on a distinguished road
EMC settings for routoutcnc drivers
Hi, I have succesuflly controlled the motors connected to the routout 2.5A driver using EMC2. However, in order to optimize this, I'd like to know how I can match time requirements of the driver as given in the data sheet:
"Timing Requirements
200nS Minimum Command active time before step pulse.
1.0uS Minimum command active time after step pulse.
1.0uS Minimum step Low time. "
with the inputs required by EMC2:
"step time" / "step space" / "direction hold" / "direction setup"
Thanks in advance!
Old 06-24-2008, 08:38 AM
Big John T is on a distinguished road
I converted it and added it to this page:
http://wiki.linuxcnc.org/cgi-bin/emc...r_Drive_Timing
Record your present settings and change one at a time then test in stepconf. If you find that the numbers need tweeking just let me know and I'll adjust the web page.
Keep in mind that you will have to pick either high speed, good torque or a comprise between the two you want with that board via the jumpers for micro stepping. High microstepping gives you best low speed performance and single stepping gives you the most speed. The other limitation is the latency of your computer and how fast pulses can be made.
I hope I helped
John
Old 06-25-2008, 01:53 AM
Many thanks, I will let you know of the results of my tests in case the web page needs some updating!
LOOKING FOR SETTINGS curlyweld CNC Plasma and Waterjet Machines 2 03-20-2008 01:14 PM
Rabbit Settings ArturoV Laser Engraving & Cutting Machines 3 12-05-2007 06:41 PM
mach 3 settings najnielkp Viper Servo drives 4 10-08-2007 06:50 PM
VF 6 Trying to get to warmup settings SpringKing Haas Mills 7 09-28-2006 09:39 AM
dnc settings jamesr Fanuc 1 02-02-2006 02:13 PM
