Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 06-18-2008, 11:33 PM
uberdude's Avatar
uberdude is on a distinguished road
spindle control
I am building a parallel port interface board for my lathe and am stuck on what method to use to control the spindle. I have figured out that the driver board for the lathe spindle is analog input (speed is determined by voltage).
The motor was designed to spin between 100rpm and 2800rpm, the old controller used 100rpm increments.
100rpm = 0.67v input
2800rpm = 8.46v input
So right to the point, should I use PWM, PPR, or PDM? I want to use something that is easy/cheat to build, and also easy on components (i.e doesn't try to spin the motor up to full speed instantly!)
Old 06-19-2008, 07:33 AM
samco is on a distinguished road
I assume you mean from the printer port? You're going to need an op-amp style low pass then.. There are tons of circuits out there.
similar to this
http://www.picbasic.co.uk/forum/showthread.php?t=245
picture of the schematic
http://www.picbasic.co.uk/forum/atta...0&d=1077243747
as far as not wanting to be a hard on/off - That could be done all in HAL. You would hook say a http://linuxcnc.org/docs/2.2/html/ma.../limit2.9.html to the pwmgen. (i may be winging it here - there may be a better solution.) Also - I think pdm works better in this situation
sam
Tags
controller, pdm, ppr, pwm, spindle
Can't control spindle Mark Jackson LinuxCNC (formerly EMC2) 3 11-05-2007 10:34 AM
Using Flashcut CNC Spindle rotate card control to control laser power pyroplotter FlashCut CNC 0 10-15-2007 09:46 PM
Spindle control BKCOM Fanuc 1 08-13-2007 10:30 PM
X3 spindle control Jed Benchtop Machines 5 06-01-2007 11:10 AM
VFD to control a spindle? What do I need? Allistah Mach Software (ArtSoft software) 7 12-07-2005 09:39 AM
