Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 06-02-2008, 07:08 PM
mxpro32 is on a distinguished road
mastercam v9 and emc2, fanuc post not working
Hi, I am trying to switch from mach-3 to emc2. I have emc2 configured and jogging properly, but I can't load a g-code that doesn't have errors. I have been trying the basic mpfan fanuc post processor. Any ideas how to output the .ngc files that emc2 wants? Thanks in advance.
Old 06-03-2008, 05:28 AM
cyclestart is on a distinguished road
MPFAN should have been close. The gcode language in emc differs a bit from straight fanuc. Some errors might be caused by how you're creating the toolpaths. Cutter compensation (G41, G42) being an example.
If the problem is syntax type errors try searching for EMCMPFAN . A search of this forum turns up a few hits. I don't know how good (or bad) those posts might be as I no longer have access to mastercam..
edit/ There's also one here
http://wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Cam
called emc.zip. At the bottom of the .pst file it claims to work with major version 9.
Maybe someone here is actively using mastercam?
Anyone who says "It only goes together one way" has no imagination.
Old 06-03-2008, 10:47 PM
harty is on a distinguished road
Hi mxpro32
i am currentlt running mastercam 9 with emc2 works very well with the emcmpfan post processor if you pm me i can send you a copy
cheers
harty
Mastercam 9 post for Fanuc 10m mroy0404 Post Processor Files 3 05-04-2007 03:15 AM
MasterCam X Fanuc 10M Post needed jonesr Post Processor Files 0 04-10-2007 09:12 PM
Mastercam post for Fanuc 16iMB control blazekka Post Processor Files 5 02-01-2007 08:49 AM
mazak v5/fanuc 6mb tool changer mastercam post edit wild01 Post Processor Files 1 10-26-2006 08:44 AM
Fanuc post for mastercam Jedi Fanuc 4 07-22-2006 09:05 PM
