| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
I have read the manual acouple of times and maybe Im not getting it or I cant do it. I dont have any limit switches but I do put the table back to 0,0. But as soon as a do a part and hit home I cannot goto the left side of the table because its past my soft limits. So I guess my question is this, Is there 2 different zero's one for parts and one for the machine. I hope this makes sense. I guess I could open up the soft limits to allow me to go back to the tables 0,0 location. But I figured I would ask before doing that. |
There is a machine origin and a fixture offset. Machine origin is HOME. Fixture offset is is another set of zeros offset some distance from HOME. Axis provides "touch-off" for creating the fixture offset. Does this help? http://www.mail-archive.com/emc-user.../msg03400.html the info in that link is an excerpt from a longer explanation found on the wiki or possibly the user manual.
__________________ Anyone who says "It only goes together one way" has no imagination. |
| Yep thats it. I will probably ask more question tomorrow when I am able to put the text to practice. Thanks for the help. I have looked at that button thinking if I hit it, it would send the Z straight down to the table seeking out a touch off switch. |
| Hope I read this situation correctly. Didn't spot it on the first read through.
| That was what I was doing. I knew there had to be a better way and everytime I looked up homing it never refered to "touchoff". Im new at this so Im learing as a go along. I probably read the touch off before but thought it was for a touch off probe and paid not attention to it. I went out to the shop and tryed it out and works great now. It even allows me to go into the negative to compensate for tool diameter. Thanks again |
| If you want a "Go to Home" button take a look at my pyVCP Adding Custom Buttons write up on the wiki site. http://wiki.linuxcnc.org/cgi-bin/emc...om_MDI_Buttons John |
| John, You know if I didnt know better I would have said you where in my garage the other day. I was thinking to myself "It would be nice if I was able to hit a button and everything went to home" Well you just proved to me that it is possible. I wont lie to you either but after reading your write up I have alot more reading to do. I dont know what a ini. postgui.hal or .xml are at all. And most of the other writting is chinesse to me to. Thanks again, now back to the book. |
| Some say I'm a mind reader and some say... well never mind. Hmmm, all those files will be or need to be in your config folder with the rest of your config files. They are all just text files that you can open and read. The .xml file is what tells EMC how to build the pyVCP. The postgui.hal file is a .hal file that is run after the gui (Axis in my case) has loaded. A .hal file is a hardware abstract layer file and it tells emc how to connect things together. the .ini file is what ever you named your config like mymill.ini. If you don't have some of the files just create them. Tell me where you get confused and I'll try and clear up the instructions. Some useful reading material... http://www.linuxcnc.org/docview/html//hal_vcp.html Enjoy John |
| CNC machine part 3 | Foxbat | Rockcliff Machine | 0 | 03-07-2008 10:41 AM |
| CNC machine part 2 | Foxbat | Rockcliff Machine | 1 | 01-31-2008 06:48 PM |
| What wil be the best way to machine this part? | chakaloso | General Metalwork Discussion | 21 | 05-15-2007 12:22 AM |
| Machine Down Need Part Bad!!!!! | joe1970 | Mazak, Mitsubishi, Mazatrol | 3 | 09-29-2005 06:36 PM |
