Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 04-23-2008, 07:42 PM
NJC NJC is offline
NJC is on a distinguished road
What do you think of EMC?
Hello all, I am considering using EMC to controll my Bridgeport. I am going to be doing a PC based software conversion to replace my old DOS controller. I was going to use Mach3 but have recently been told that my servo drives need PWM inputs and that Mach only has step and direction outputs. I was planning on using a Pico systems controller that uses PWM and John from Pico says his board works perfectly with EMC. I don't have any Linux experience at all, never used it. How do you like EMC? What are the pros and cons of the software? If you have used Mach3 and EMC, which do you like better? Is it user friendly?
Thanks.
Scott
Old 04-23-2008, 10:17 PM
skullworks is on a distinguished road
Thumbs up EMC?
Scott;
I admit I'm a computer geek and Linux is just another O/S to me.
But:
Get yourself a copy of the latest EMC2 Live CD - Don't even install it. Just boot to it and play with some of the SIM configs.
Actually Installing is almost as easy. The Live CD can do a Ubuntu Linux install with the EMC program allready setup in basic configs. The Pico Systems hardware drivers are allready in the EMC bundle.
Help is almost always available on the #EMC irc.
Try it, I think you will like it.
Old 04-24-2008, 12:57 AM
klick0 is on a distinguished road
I've only ever used EMC to drive my machine, I love it, granted however I know nothing else. I recently purchased some equipment from pico systems (john) but have yet to use it, i'm building a new cnc machine and once it's done it'll be using the pico systems universal stepper controller.
EMC has always worked great for me though, no software failures (my cnc machine has screwed up before eheh, but that's my fault).
Ross
Old 04-24-2008, 07:37 AM
cyclestart is on a distinguished road
If you go this route you're married to emc afaik.
Very much. Emc users are relatively small in numbers but large in enthusiasm.
If you are used to a big brand CNC the control in emc can be a bit clumsy. Not sure if Mach fares much better in this type of comparison.
emc is much more than mill/lathe software. Most of us have only scratched the surface of it's capabilities as a machine control.
Limited Mach experience. As a motion control it may be a sawoff. Realtime kernel has a theororetical advantage.
Compared to to Mach there is less documentation and fewer wizards. This gap is closing somewhat.
If this is your first experience with *nix there is a learning curve. Ubuntu eases the transition a great deal.
Old linux joke: Linux is user friendly, it's just particular who it chooses for friends.
Don't let this scare you off
Anyone who says "It only goes together one way" has no imagination.
Old 04-24-2008, 08:26 AM
Big John T is on a distinguished road
I used EMC on my plasma table and it is highly configurable. Some of the documents are a bit terse but the irc and mailing list is full of helpful people when you hit a snag.
Pros
It is open source
It is real time
It is configurable
It is being improved every day
It cost you nothing but some time to try it out
Cons
The docs are lacking
It won't work on a laptop afaik
Linux can take a bit to get use to if your a seasoned window user but, Unbuntu makes it as easy as possible...
Oh, yes don't forget the wiki site it is full of info...
John
Old 04-24-2008, 07:46 PM
NJC NJC is offline
Well, sounds like you all are happy with it, I was hoping to hear that. Sounds like the technical part of the software is very well thought out and works well. Maybe Mach has more bells and whistles, like the wizards. I was told that EMC allows use of the machine manually as well as with the controller and that Mach doesn't allow one to use it manually, is this true? Would be nice to be able to do simple tasks quickly without programming. I'm used to setting up my work now manually, I don't have a thumbwheel or anything like that, it's a real simple system, I kinda like it that way.
Thanks for all the unput!
Scott
Old 04-24-2008, 08:41 PM
cbcnc is on a distinguished road
Let's not forget about the fact that you don't need a super computer to run EMC2. I'm using it on a 650 mhz PIII. Well maybe a little faster would be better for the GUI. But Ubuntu Linux and EMC get along fine on simpler machines. Check the recommended hardware list.
EMC Wiki Hardware Requirements
Chris
Old 05-11-2008, 12:17 PM
andy55 is on a distinguished road
for generating PWM output there is also the Pluto-P which connects to the parallel port and the M5i20, a PCI card, so you might want to consider these too.
my machine is not a bridgeport but it uses DC-servos, pwm amplifiers from Jon Elson, and an m5i20 + EMC2 to control it all. Videos here:
http://www.cnczone.com/forums/videos/
You mentioned manual machining. If you leave the handwheels on the mill you can use EMC2 or make a custom program to use your computer as a DRO - only displays coordinates no cnc control.
Old 05-11-2008, 12:42 PM
Al_The_Man's Avatar
Has anyone got PC Motion Control Cards to work in EMC?
Old 05-11-2008, 01:34 PM
samco is on a distinguished road
You have asked this a few times.. Maybe I need to ask - why do you think emc needs to support motion control cards? (really - I don't see a need). Emc2 does motion within itself. Any hardware that moves motion outside of emc isn't a good match. It would make emc2 not emc2 . Emc2 only requires 'dumb' cards that count encoders and maybe a few dac's, adc's or PWM if your build requires that. Emc closes the pid loop within software.
I love this quote from one of the emc2 developers
Again - this goes back to emc2 being the motion controller. Equipment that moves the motion outside of emc isn't a good match. EMC is a closed-loop motion controller, unlike anything else that's affordable by hobbyists. Steppers only work because EMC fakes itself out with a made-up position value for the loop control.
I don't have experience with gali or such - is there anything that it does that emc doesn't? Price wise - how do they compare to emc supported hardware? 4/8 axis card from mesa with +/- 10v 4 axis card and 2 24 i/o isolation boards costs around 199+69X3=$406. this gives you 4 axis + 32in 16out. You can look at other hardware here.
http://wiki.linuxcnc.org/cgi-bin/emc...orted_Hardware
pico systems has some nice cards also.
(still - low budget you could even run PWM out the printer port and read encoders back in)
sam
Old 05-11-2008, 02:15 PM
Al_The_Man's Avatar
I have asked it a few times and have received mixed inconclusive answers.
May it is because I am not fully aware as to how EMC closes the loop?
If it is closed withing the EMC s/w, then I would have though it wuld have been open to other forms of servo drive control such as 10v analogue?
Also Does it support master/slave gearing and electronic cam etc?
  #12   Ban this user!
Old 05-11-2008, 02:41 PM
Cool EMC supported hardware.
Actually analog +/- 10V hardware is one of the best matches for EMC and can be implemented a number of different ways.
Step/Dir type servo drives which treat a servo like a high priced stepper drive are supported but waste much of EMC's capability.
Velocity mode (vrs steps) can run on a pIII-600 with marginal CPU loading - Try that on a Mach 3 based system.
Likewise EMC preferably homes using an Index (aka Z channel) - so E-Stop or powering a machine down doesn't require reseting all your offsets.
Emc also supports rigid tapping and being open source is constantly having new features added.
Often EMC may not support something because no one has yet had the need for a function, but things get added as needed.
A good example is 5 axis tool offsets...
Check out Stuart's Cinnci -
