| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
Hi i'm a newbie to cnc. I'm using emc2 software and I have no trouble getting the examples to work. My question is how do I get a drawing from whatever software i'm going to use to the .ngc file format that emc likes. |
| I use emc2 also. I started out using NCPlot2 under Windows to convert a DXF file to gcode. I also have VCarve for fancy engraving, but most of the time I just write the gcode by hand. Alan
__________________ http://www.alansmachineworks.com |
| I generally try to avoid Windows like the plague, but there are a number of CAD programs for Windows and NCPlot or VCarve will import a DXF file and produce output for emc2. Vectrix also sells Cut2D and Cut3D programs, Vectrix has a post processor that works for emc2. You can get a free demo copy of QCAD for Linux, Mac or Windows and the license fee is only 35-40 dollars. Alan
| I have been using CamBam under windows to generate G-code. Works great and the price is right. http://www.brusselsprout.org/CAMBAM/ Stan |
| I know EMC2 supports the use of image files. I have not tried it though. You have to turn it on as [FILTER], in your .ini file. Check chapter 23 in the EMC2 user manual about image-to-gcode. Well worth a try. "One pixel in the input image will be this many units–usually this number is much smaller than 1.0. For instance, to mill a 2.5x2.5-inch object from a 400x400 image file, use a pixel size of .00625, because 2.5 / 400 = .00625." Last edited by loboy; 05-20-2008 at 05:25 PM. |
| Thanks for all the replies and help. I have been using cambam to generate the gcode and it works great. Still learning but, have come a long way. I still have not figured out how to cut a vertical curve in a stock of wood. Any ideas anyone. |
| MSC Milling machine drawing | Jim Estes | General Metal Working Machines | 0 | 04-16-2008 08:50 PM |
| Need Help!- Milling Machine Setup File | seal1966 | BobCad-Cam | 0 | 01-25-2008 01:54 PM |
| Is my drawing ok? *file now attached* | Zamm | Musical Instrument Design & Construction | 4 | 06-26-2007 04:17 PM |
| Drawing help | dwacker | Dolphin CADCAM | 11 | 05-08-2007 03:53 PM |
| Newbie question: how do I machine this? (Drawing attached) | Aegeon | General Metalwork Discussion | 20 | 12-04-2005 01:20 PM |
