| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
So I'm looking to build a small mill and I'd like to get an all inclusive electronics package ( motor controller, motors power supply, etc.) that will work with EMC with little trouble and hopefully little to no wiring. I was looking at this xylotex setup http://www.xylotex.com/Econo4AxSpecial.htm but i keep reading poor reviews about the drivers and I'd like something that will last for a while. To me electrical problems are the worst. So even though I can usually fix the problem, I would prefer to just not have to. So buying a quality plug and play or close to plug and play setup would be nice. Oh and it absolutely has to run on EMC, I fell in love with ubuntu and theres no going back to windows . Any suggestions for where I should start? Thanks for any input in advance, -Eric |
| Hello Eric, I had elected to go with brushless DC motors and CNCTeknix's ( Australian designers and suppliers) TEK6 servo driver amplifiers. CNCTeknix also have a parallel port breakout card opto isolated interface and relay card which neatly interface with each other. All you need do is provide +5V and +24V for relay driven interface. I obtained the brushless DC motors from Anaheim Automation ( 36 Volt motors runing on 24 volts since the TEK 6 is good for only 28V. The nice thing about TEK6 is that it is fully connectorised so that building up the system is done without a need for soldering iron. Having said that i did modify TEK6 since i opted for a linear position transducer with a db15 header Tuning TEk6 is a bit of problem.. the tuning is done via a windows application which talks to TEK6 via an RS232 port.so you need two pc one to run the axis ( EMC2 machine) and the other to run tuning application under windows. Otherwise its a very nice driver. |
| pros Setup couldn't be easier. Case is tidy and sturdy. Screw terminals for access to additional pins. cons no circuit protection. Disconnect a motor while powered up and it will blow. Worst case scenario, $155 for a new board. Limited support. No phone calls. Email is either unreliable or sometimes ignored. Only Xylotex knows which for certain. It's low power. You appear to be aware of that. Good enough for my X2. Some members prefer combos from here; http://www.kelinginc.net/CNCPackage.html btw, Gecko has budget drivers coming out (soon?) . Gecko's customer support is first rate by all reports. Overall I'm satisfied with my Xylotex purchase so far.
__________________ Anyone who says "It only goes together one way" has no imagination. Last edited by cyclestart; 04-17-2008 at 06:57 AM. Reason: can't spell |
| Zig - thanks for the input but I'm thinking that the CNCTeknix setup would be a little bit out of my league for now... cyclestart - I think I may just end up going with the Xylotex combo and taking my chances. I guess the worst case scenario if I ever blow up the driver I could just get buy a gecko drive that has all of the fail safes and just drop it in. Does that sound feasible? Thanks again guys for your input. -Eric |
| Maybe one of the electronically competent can answer whether dropping in a gecko is feasible. Depends on the type of failure possibly. Running any gecko at 24V seems a bit of a waste.
__________________ Anyone who says "It only goes together one way" has no imagination. |
What ever you do make sure you have the power you need for your machine or you will be disappointed... John |
| How many axis' does the gecko 203v board support? Is it three or four on one board or would i need 3 gecko 203v's to run one mill? Thanks for your help. -Eric
| Alan
__________________ http://www.alansmachineworks.com |
| Yeah see the problem with that is cost. To get a system together at that point it would cost $300 more than an equivilant system by xylotex. Now if I had the money i would do that but i think the xylotex system is going to have to be it for now. -Eric |
#10
| John |
#11
-Eric |
#12
Maybe it's time to define small. That xylotex setup is low power with components to match. Budget stuff but very capable for mills like my X2. A blown board is an IF not a WHEN, at least within reasonable lifespan expectations. Mine has run a year of moderate use, expect it will still be running next year. If it breaks it gets repaired. Certainly not the most expensive part of this hobby. The kelinginc kits I linked earlier have circuit protection and a one year conditional warranty. Keling has a reputation for good customer service. If moneys not an issue gecko 203's are good stuff. Possibly overkill depending on the mill. Have you read the "cheap drives" thread in the gecko forum ? Worth a look if money is an issue. Any thoughts of grafting geckos into the xylotex combokit are best forgotten imo. edit/ Is this mill for heavy or occasional use? Would a small bit of downtime be an inconvenience or disaster?
| GOTO Z button | TMaster | Mach Mill | 10 | 05-30-2009 07:18 AM |
| Newbie- Button Oiler - How to use. | Eric Q. | Shopmaster/Shoptask | 7 | 03-14-2008 11:40 PM |
| Help with e-stop button | Astroguy | Xylotex | 2 | 05-31-2007 07:23 AM |
| configure run button | xtihc | Mach Software (ArtSoft software) | 1 | 05-25-2006 04:57 PM |
| so that is what that button does | johnm | Test Forum | 0 | 03-26-2003 03:43 PM |
