Page 1 of 3 123 LastLast
Results 1 to 12 of 28
Thread: M8 still not being red by EMC2
    Registered SpeedsCustom's Avatar
    Sep 2006
    Hey guys, I'm still having this annoying problem that EMC won't read the m8 command. I have a CNC4PC multifunction BOB. Pin 1 in Stepconf is designated for the Coolant. When I "INVERT" the pin, plugging in my pump works. When it's normally set, no invert. It will not read M8. I simply open up my g-code and put in m8 and m9 and resave the file.
    I'm not sure how too modify my Hal, All I know is too access stepfconf and change those things around, Pins, etc...
    I really need it too work with m8 and m9. I don't like too plug and unplug it.
    Please help,
    -Jason
    Jul 2003
    Holmen, WI
    post your .hal file.
    Sep 2006
    How do I access my Hal, I don't know where too go.
    -Jason
    Jul 2003
    Holmen, WI
    easy way (windows users way )
    go to the top menu bar - second menu over is 'Places'
    open that up and you get a 'home folder' menu item. This is like a file broweser. It opens in your 'home' directory. (usually your name you setup).
    There should be an 'EMC2' directory. Double click and it will open. Under that is usually 2 folders - Configs and NC_files. Double click on the 'Configs' directory. Under that should be a directory with the name of the config you pick from the list. Double click on that and your ini and hal files should be in that directory. Double clicking on either the hal or ini files should open them up in Gedit - a gui file editer. (it might ask you if you want to dispay or run in terminal - you want to display) You can make changes to them and save at this point.
    For this purpose - open the hal file up in gedit and paste it here.
    sam
    Sep 2006
    Oh thanks! Will do!
    -Jason
    Sep 2006
    What a freaking pain, I don't have internet access in the shop. So i tried putting my files onto a disk and Linux is being stupid and won't let me, I'll have to try and figure out how too transfer them....Argh
    -Jason
    Jul 2006
    United States of America
    When I don't have a network available, I use a usb flash drive ,which are really inexpensive for usable sizes and sometimes transfer files to my camera.
    Kirk, http://www.wallacecompany.com/machine_shop/
    Sep 2006
    Wallace, thats what I use too transfer all my g-codes. It won't allow me too send it there!
    Or copy it in....
    -Jason
    May 2005
    canada
    Quote Originally Posted by kirk_wallace View Post
    Write to the camera's memory card via usb? Must try that some time. Very ingeneous.
    SpeedsCustom
    cd/dvd or floppy? Both [i] should [i] work np. Not saying will work np. Computers can be obstinate beasts.
    Anyone who says "It only goes together one way" has no imagination.
    Jul 2006
    So you can open a .hal or .ini file in your "/home/your_home/emc2/configs/your_config" in gedit, as described by samco above? But if you do something like "Save As" to your flash disk, it fails? What is the error message? Try bring up "/home/your_home/emc2/configs/your_config" as before but this time right-click on the .ini file, go to the bottom of the list and select "Properties", then "Permissions". See who is listed as "File owner" and "File Group". Your username should be there and not "root". Also check the "Owner", "Group" and "Others" check marks for "Read", "Write" and "Execute". "Owner" should have a check mark for "Write", all the "Read"'s should be checked. Then check the permissions for your flash drive. You will need to have "Write" permission to your drive. Another way to try this is to bring up a terminal session (Applications, Accessories, Terminal) and change to "root" with "sudo su -". Root has permission to do just about anything, so permission for a file copy should not be a problem. Let us know what error or other messages you get. You are our eyes and we can't help without being able to see.
    Sep 2006
    I'm working on this, give me like a day, I'm dealing with so many other things. I'll try and copy too a CD if the USB flash don't work.
    It says error, cannot copy too device, it is a READY only???
    -Jason
    Sep 2006
    Ok Now Were set:
    PHP Code:
    # Generated by stepconf at Mon Apr  7 18:14:08 2008
    # If you make changes to this file, they will be
    # overwritten when you run stepconf again
    loadrt trivkins
    loadrt
    [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD traj_period_nsec=[EMCMOT]SERVO_PERIOD key=[EMCMOT]SHMEM_KEY num_joints=[TRAJ]AXES
    loadrt probe_parport
    loadrt hal_parport cfg
    =0x378
    setp parport.0
    .reset-time 4000
    loadrt stepgen step_type
    =0,0,0
    loadrt charge_pump
    net estop
    -out charge-pump.enable <= iocontrol.0.user-enable-out
    loadrt pwmgen output_type
    =0
    addf parport.0
    .read base-thread
    addf stepgen
    .make-pulses base-thread
    addf charge
    -pump base-thread
    addf pwmgen
    addf parport.0
    .write base-thread
    addf parport.0
    .reset base-thread
    addf stepgen
    .capture-position servo-thread
    addf motion
    -command-handler servo-thread
    addf motion
    -controller servo-thread
    addf stepgen
    .update-freq servo-thread
    addf pwmgen
    .update servo-thread
    net spindle
    -cmd <= motion.spindle-speed-in => pwmgen.0.value
    net spindle
    -enable <= motion.spindle-on => pwmgen.0.enable
    net spindle
    -pwm <= pwmgen.0.pwm
    setp pwmgen.0
    .pwm-freq 100.0
    setp pwmgen.0
    .scale 1166.66666667
    setp pwmgen.0
    .offset -133.333333333
    setp parport.0
    .pin-01-out-invert 1
    net coolant
    -flood => parport.0.pin-01-out
    net xstep
    => parport.0.pin-02-out
    setp parport.0
    .pin-02-out-reset 1
    net xdir
    => parport.0.pin-03-out
    net ystep
    => parport.0.pin-04-out
    setp parport.0
    .pin-04-out-reset 1
    setp parport.0
    .pin-05-out-invert 1
    net ydir
    => parport.0.pin-05-out
    net zstep
    => parport.0.pin-06-out
    setp parport.0
    .pin-06-out-reset 1
    setp parport.0
    .pin-07-out-invert 1
    net zdir
    => parport.0.pin-07-out
    net astep
    => parport.0.pin-08-out
    setp parport.0
    .pin-08-out-reset 1
    net adir
    => parport.0.pin-09-out
    net estop
    -out => parport.0.pin-14-out
    net spindle
    -pwm => parport.0.pin-16-out
    net charge
    -pump => parport.0.pin-17-out
    setp stepgen.0
    .position-scale [AXIS_0]SCALE
    setp stepgen.0
    .steplen 1
    setp stepgen.0
    .stepspace 0
    setp stepgen.0
    .dirhold 45300
    setp stepgen.0
    .dirsetup 45300
    setp stepgen.0
    .maxaccel [AXIS_0]STEPGEN_MAXACCEL
    net xpos
    -cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
    net xpos
    -fb stepgen.0.position-fb => axis.0.motor-pos-fb
    net xstep
    <= stepgen.0.step
    net xdir
    <= stepgen.0.dir
    net xenable axis.0
    .amp-enable-out => stepgen.0.enable
    setp stepgen.1
    .position-scale [AXIS_1]SCALE
    setp stepgen.1
    .steplen 1
    setp stepgen.1
    .stepspace 0
    setp stepgen.1
    .dirhold 45300
    setp stepgen.1
    .dirsetup 45300
    setp stepgen.1
    .maxaccel [AXIS_1]STEPGEN_MAXACCEL
    net ypos
    -cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd
    net ypos
    -fb stepgen.1.position-fb => axis.1.motor-pos-fb
    net ystep
    <= stepgen.1.step
    net ydir
    <= stepgen.1.dir
    net yenable axis.1
    .amp-enable-out => stepgen.1.enable
    setp stepgen.2
    .position-scale [AXIS_2]SCALE
    setp stepgen.2
    .steplen 1
    setp stepgen.2
    .stepspace 0
    setp stepgen.2
    .dirhold 45300
    setp stepgen.2
    .dirsetup 45300
    setp stepgen.2
    .maxaccel [AXIS_2]STEPGEN_MAXACCEL
    net zpos
    -cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
    net zpos
    -fb stepgen.2.position-fb => axis.2.motor-pos-fb
    net zstep
    <= stepgen.2.step
    net zdir
    <= stepgen.2.dir
    net zenable axis.2
    .amp-enable-out => stepgen.2.enable
    net estop
    -out <= iocontrol.0.user-enable-out
    net estop
    -out => iocontrol.0.emc-enable-in
    loadusr
    -W hal_manualtoolchange
    net tool
    -change iocontrol.0.tool-change => hal_manualtoolchange.change
    net tool
    -changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
    net tool
    -number iocontrol.0.tool-prep-number => hal_manualtoolchange.number
    net tool
    -prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
    PHP Code:
    [EMC]
    MACHINE Taig
    NML_FILE
    emc.nml
    DEBUG
    [DISPLAY]
    DISPLAY axis
    POSITION_OFFSET
    RELATIVE
    POSITION_FEEDBACK
    ACTUAL
    MAX_FEED_OVERRIDE
    1.2
    INTRO_GRAPHIC
    INTRO_TIME
    5
    PROGRAM_PREFIX
    = /home/speedscustom/emc2/nc_files
    INCREMENTS
    .1in .05in .01in .005in .001in .0005in .0001in
    PYVCP
    panel.xml
    [TASK]
    TASK milltask
    CYCLE_TIME
    0.010
    [RS274NGC]
    PARAMETER_FILE emc.var
    EMCMOT]
    EMCMOT motmod
    SHMEM_KEY
    111
    COMM_TIMEOUT
    1.0
    COMM_WAIT
    0.010
    BASE_PERIOD
    100000
    SERVO_PERIOD
    1000000
    [HAL]
    HALFILE Taig.hal
    HALFILE
    custom.hal
    POSTGUI_HALFILE
    custom_postgui.hal
    [TRAJ]
    AXES 3
    COORDINATES
    X Y Z
    LINEAR_UNITS
    inch
    ANGULAR_UNITS
    degree
    CYCLE_TIME
    0.010
    DEFAULT_VELOCITY
    0.10
    MAX_LINEAR_VELOCITY
    0.30
    [EMCIO]
    EMCIO io
    CYCLE_TIME
    0.100
    TOOL_TABLE
    tool.tbl
    [AXIS_0]
    TYPE LINEAR
    HOME
    5.98
    MAX_VELOCITY
    0.3
    MAX_ACCELERATION
    30.0
    STEPGEN_MAXACCEL
    31.5
    SCALE
    4000.0
    FERROR
    0.05
    MIN_FERROR
    0.01
    MIN_LIMIT
    0.1
    MAX_LIMIT
    11.9
    HOME_OFFSET
    5.98
    [AXIS_1]
    TYPE LINEAR
    HOME
    3.0
    MAX_VELOCITY
    0.3
    MAX_ACCELERATION
    30.0
    STEPGEN_MAXACCEL
    31.5
    SCALE
    4000.0
    FERROR
    0.05
    MIN_FERROR
    0.01
    MIN_LIMIT
    0.1
    MAX_LIMIT
    6.0
    HOME_OFFSET
    3.0
    [AXIS_2]
    TYPE LINEAR
    HOME
    0.25
    MAX_VELOCITY
    0.2
    MAX_ACCELERATION
    25.0
    STEPGEN_MAXACCEL
    26.25
    SCALE
    4000.0
    FERROR
    0.05
    MIN_FERROR
    0.01
    MIN_LIMIT
    = -6.0
    MAX_LIMIT
    0.26
    HOME_OFFSET
    0.25
    Now this should be good! Thanks for helping!
  • Page 1 of 3 123 LastLast
    1. EMC2 to diy CNC
      By dakiller322 in forum LinuxCNC (formerly EMC2)
      Last Post: 10-05-2007, 01:16 AM
    2. How to install EMC2
      By cut more in forum LinuxCNC (formerly EMC2)
      Last Post: 07-18-2007, 09:19 AM
    3. Emc2
      By sdantonio in forum Mach Mill
      Last Post: 02-05-2007, 03:26 PM
    4. emc2 -hal*?
      By essa in forum LinuxCNC (formerly EMC2)
      Last Post: 05-27-2006, 01:06 PM
    5. emc2
      By heilcnc in forum LinuxCNC (formerly EMC2)
      Last Post: 05-23-2006, 06:03 PM
