| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
I have finally got my machine up and running. I am using a mesa 5i20 card and emc2 2.2.3 I have managed to tune the servos to the best of my ability however I would like to have the machine move faster for rapids and overall performance. It seems as though the maxium vecocity I get up to is 60ipm. At least that what the maxium value displayed in Axis when i run programs. I would like to increase this speed however when I cange the velocity values I get following errors. I wanted to find out if anyone knows which setting I should be changing. I have included my ini file so hopefully someone can shed some light on increasing this speed. Any help would be appreciated. Thanks |
| I too am seeing following error flag being raised. from what litle i understand the software is being asked to execute a path with a given following error. There are two settings relating to following error and they are defined in AXIS_n definitions as follows FERROR = 0.020 MIN_FERROR = 0.01 FERROR is applicable to high speed movements and MIN_FERROR to low speed coordinated movements. try FERROR = 0.055 or even larger You have set AXIS_0 MAX_VELOCITY = 1.0 MAX_ACCELERATION = 10.0 and AXIS_1 MAX_VELOCITY = 1.0 MAX_ACCELERATION = 5.0 At the same time TRAJ trajectory planner is set to DEFAULT_VELOCITY = 1.0 MAX_VELOCITY = 1.0 DEFAULT_ACCELERATION = 3.0 MAX_ACCELERATION = 10.0 try something much larger in maximum velocity say MAX_VELOCITY = 3.0 And MAX_ACCELERATION similarly larger in the trajectory planner than the correspnding setting for the AXES say MAX_ACCELERATION = 15 I hope my understanding is correct, and applicable to Your set up as I am using simple stepper control driving a BLDC in a closed loop config via parallel port. Almost forgot... In the EMCMOT section you have BASE_PERIOD = 50000 This sugests that the latency of your PC is rather mediocre. If you have not done so already do run latency-test and post the results. I would think that if You want better top end performance BASE_PERIOD needs to be about half of what you have. However since this parameter is influenced by the PC motherboard latency-test is the only arbiter of what it ( BASE_PERIOD) can be for reliable not fast operation. Hope this helps Zig |
| Possible to increase spindle speed? | jinu117 | Syil Products | 12 | 12-24-2007 08:20 AM |
| Mesa de coodenadas. | Mentus | Spanish CNCzone | 3 | 12-11-2007 04:34 PM |
| More Speed needed. Bigger Stepper or increase Ballscrew Pitch ? | Joey | Stepper Motors and Drives | 12 | 11-30-2007 02:07 PM |
| How do I increase spindle speed? | cnczoner | General Electronics Discussion | 8 | 07-11-2007 08:42 AM |
| Excellent, Speed Increase | snoyce | DIY-CNC Router Table Machines | 5 | 04-04-2007 02:06 PM |
