Results 1 to 3 of 3
Thread: How to use index pulse for homing purpose
    Zig
    Zig is offline
    Mar 2008
    I am in the process of building a machine, a simple xyz gantry.
    The machine runs on EMC2 using linear scale / BLDC servo loops implemented in external hardware. EMC provides control signals step and direction and is configured a ssimple stepper motor controller.
    Machine behaves quite nicely. It recognises end of travel limits. Test plots ( in lieu of actual machining ) comes up well.
    The linear scale generates home index pulse.
    I understand that EMC allows a motion control interface card to recognise the pulse.
    Is there a way of interfacing the pulse NOT A LIMIT SWITCH to be recognised as home location in absence of such a motion control card.
    Any suggestion is welcome.
    Mar 2003
    Shelby Twp, MI....USA
    Zig
    Zig is offline
    Mar 2008
    Ger21,
    Thanks for the info.
    On further reflection I think all I need do is extend the pulse ( a monostable) so that EMC has time enough to reverse the direction of travel and cross the index pulse back fronm the other side for a second this time slower home latch pass.
    ( this is set up by making both home search and home latch velocities of same polarity / direction )
    Will keep you posted.
    EDITED 18.27 march 29 2008
    Well a day has passed and the idea works. This would not work on a rotary encoder with many index pulses since multiple home positions would be available. I am using linear scales and since there is a unique index pulse it latches.
    The solution could work with a rotary shaft encoder if one marked the range over which the homing is to take place and the range included only one index pulse. his might obviate the expense of home position switch and provide superior homing location provided by the index pulse.
  1. Unfit Pulse Of Pulse Coder Alarm
    By Crashmaster in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 04-23-2007, 10:55 AM
  2. coolant purpose?
    By jprobst in forum Haas Mills
    Last Post: 02-20-2007, 10:42 PM
  3. Phototransistor + Index Pulse = Z Axis THC?
    By sunmix in forum Mach Software (ArtSoft software)
    Last Post: 10-26-2006, 10:30 AM
  4. Fit for the purpose (I think)
    By polus in forum DIY CNC Router Table Machines
    Last Post: 05-01-2006, 12:26 PM
  5. Purpose
    By kdoney in forum CNC Wire Foam Cutter Machines
    Last Post: 01-15-2005, 11:05 AM
