Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 03-17-2008, 07:49 AM
samco is on a distinguished road
EMC 2.2.4 released
You can read about it here..
http://axis.unpythonic.net/
make xxxmach exit reliably with 'halcmd unload' (SF#1816781)
hook up encoder index for homing in the motenc sample configuration
axis: don't reset the interpreter during touch-off and reload. This fixes the loss of modal settings from MDI, including tool length offset, fixing SF#1825638
stepconf: clarify that it is the ratio of teeth on each pulley that must be entered
hal_input: fix 'ZeroDivisionError' for absolute axes that report the same value for min and max
fix various inaccuracies in the documentation
halscope: fix the time displayed when mousing over a trace
axis: fix ctrl and - or = starting an unstoppable jog
axis: fix the numeric keypad with numlock on
task: fix the initial coordinate system offset (SF#1895693)
stepconf: fix "Both Limit"-type inputs (SF#1906640)
stepconf: fix "HOME_SEQUENCE" problem without full set of home inputs (SF#1906641)
stepconf: fix Z home and limit switches on lathes (SF#1910452)
stepconf: fix 'offset' value calculated for spindle speed control
stepconf: enable 'dither-pwm' for spindle speed control
traj planner: fix velocity 'bobble' between 1st and 2nd consecutive synced moves
halscope: fix 'sample every Nth time' function
configs/univstep: fix external estop in this configuration
pluto_step: fix for negative scale values (SF#1915407)
pluto_servo: fix for pwm+direction mode
stepconf: improve calculation of HOME_LATCH_VEL
Old 03-17-2008, 08:12 AM
cyclestart is on a distinguished road
Do the gurus ever stop to sleep, go to work, etc?
Good stuff as usual I'm sure.
Anyone who says "It only goes together one way" has no imagination.
Old 03-17-2008, 12:33 PM
Big John T is on a distinguished road
They work but don't sleep. My thanks to them for all the effort...
John
Old 03-18-2008, 10:54 AM
cadmonkey's Avatar
cadmonkey is on a distinguished road
That is a very thorough changelog! Good work to the crew who knows how to do all that programming!
Damnit, now I have to rerig my network connection to get 2.2.4......
Old 03-18-2008, 11:04 AM
acondit's Avatar
acondit is on a distinguished road
cadmonkey,
I just go to this URL and download the .deb ( emc2_2.2.4_i386.deb), put it on a thumb drive, take it out to the shop machine, copy it to the desktop and double click it.
http://www.linuxcnc.org/emc2/dists/d...2/binary-i386/
Alan
http://www.alansmachineworks.com
Old 03-18-2008, 11:57 AM
cadmonkey's Avatar
Thanks for the tip, I'll probably just wait since 2.2.8 will probably be out by the time I finish machining my ballscrews anyway :P
Express Released artcam ArtCam Pro 0 12-14-2007 09:22 AM
VCarve Pro 4.5 has been released. bsimages Vectric 6 11-14-2007 05:34 PM
When Does X Get Released? CAMCRASH Mastercam 17 04-21-2005 02:23 AM
TurboCNC 4.0 has been released! chuckknigh DIY-CNC Router Table Machines 1 08-26-2004 10:55 PM
MeshCAM 1.0 Released robgrz Product Announcements & Manufacturer News 0 05-31-2004 08:55 PM
