Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 03-16-2008, 09:55 PM
randyf1965 is on a distinguished road
EMC2 latency from Network card
I installed EMC2 (2.2.2.1) then updated via the update manager. When I run a latency-test with the network card disabled it is under 15,000 BUT if I enable the nic it jumps to 30K-51K and jumps around in the mid 20k, if I disable the nic and restart the test it is less than 15k.
I have moved the nic to a different slot, I have not tried a new nic, curently the only 1 I have (an IBM10/100 card using an AMD chipset edvice manager lists as a PCnet32 LANCE.
I know I can disable the nic when using emc so that isn't a problem. Has anyone seen this before?
IF I could get my Netgear wg311v2 working under Ubuntu it might not be an issue... well it won't be an issue since I don't have a hard wired network connection at my router right now.....
Old 03-22-2008, 10:08 PM
Solution.....
Went to TigerDirect bought a Trendnet TEW-441PC wireless adapter for $30. I had spent 3+ hours trying to get the Netgear working only took maybe 5 minutes to get the other card working.
Latency over 15+ minutes 15,363 and that is pulling 12+mb of updates and installing plus surfing the web
network card for biese rover 342 sdqw Commercial CNC Wood Routers 3 02-17-2008 03:40 AM
Milltronics MB-19 network card jetski Milltronics 14 10-19-2007 10:05 AM
Hurco network card Piobaire HURCO 1 08-22-2007 10:24 PM
Mach 3 Wireless Network Card Interference bill south Mach Mill 5 07-13-2006 02:25 PM
Latency, Jitters & Lost Steps Imagineering TurboCNC 22 07-22-2005 07:39 AM
