Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 03-12-2008, 06:27 PM
Gads is on a distinguished road
Joint following error
help..
acquired a laptop with more mem and speed and setup emc on this all seemed ok untill i started doing some long rapids and system sets error and looses steps. have double checked latency approx 14000. the rest of the system less the laptop was running fine on old 450mhz desktop prior to swap.
getting joint follow errors when rapiding for any distance. I have changed vel. and acc. in stepconfig.ini played with latency nothing.
can these settings be changed globaly in my ini file or run stepconfig.
I ask because rapids dont sound the same as what i get when testing in the stepconfig wizard. system runs everything program wise.
stepper system
ubuntu 6.06
emc 2.2.3
Thanks gads
Old 03-14-2008, 11:52 AM
Big John T is on a distinguished road
Laptops are not for real time...
John
Old 04-10-2008, 10:50 PM
Ryobiguy is on a distinguished road
Yeah probably, but... If the latency is 14000, does it matter that it's a laptop? That's a direct measurement of just how real-time it is.
Assuming you're using a parallel port, does your laptop have a weaker voltage on the pins? Maybe with a weaker signal the motor driver inputs are picking up more noise when the motors are moving quickly.
Just a wild guess to check the electrical side of things.
Old 04-11-2008, 09:02 AM
The problem with laptops is not the latency it's the nasty habit they have of shutting down and interrupting the processing which gives you missed steps etc...
John
How do I cut carbon fiber (Joint Strike Fighter)? vettespeed Composites, Exotic Metals etc 32 06-26-2010 03:59 AM
joint venture in China JennyYin Product Announcements & Manufacturer News 0 11-06-2006 02:21 AM
slip-ring, electric swivel / rotary joint DrStein99 Mechanical Calculations/Engineering Design 13 08-09-2006 07:39 PM
help with screw joint in cosmosmotion posix Solidworks 1 01-17-2006 05:40 AM
Intersting robotic joint Zathras Mechanical Calculations/Engineering Design 9 10-07-2005 01:05 PM
