Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 03-05-2008, 09:18 AM
hooeey is on a distinguished road
Problem using EMC with MESA 5I20 + 7I33 + 7137
I have to control an engraving machine using wiring with Panasonic drivers with MESA 5I20 + 7I33 + 7137 cards.
Somehow, when running a G-code program to machine stuff, the machine is unable to go to the correct x,y & z coordinates and also exhibit the wrong feedrate. The machine also experience jerks if the coordinates are near to each other.
I am still wondering what went wrong. Any advice?
Old 03-05-2008, 10:12 AM
unterhaus is on a distinguished road
what system of measure are you using? Using metric units can sometimes cause these sorts of problems.
Old 03-05-2008, 10:20 AM
I had changed the units in use and their values to metric in the ini file . But how is that a problem?
Old 03-05-2008, 10:26 AM
samco is on a distinguished road
there are a lot of things to setup when using servos..
This is a basic outline.
http://wiki.linuxcnc.org/cgi-bin/emc.../HAL_PID_Loops
Old 03-05-2008, 10:46 AM
Tks for the tuning post. However, I had finished most of the tuning steps including testing the machine using 1 axis. That works well.
But when I run a whole G-code program, the machine behaves differently. The EMC looks as if either it has skipped lines of G-code or read the G-code so fast that the machine is unable to catch up with the codes and moves in jerks due to quick changes in coordinates.
I had also changed the values of P, I and D in ini file but no avail.
Old 03-05-2008, 03:07 PM
I don't remember exactly, but there are settings that don't make as much sense on a metric machine. You probably want to log on to the IRC channel and see if there is someone there who has better memory than I do.
Old 03-05-2008, 03:39 PM
Randomly? Normally you run short moves while using halscope - viewing among other things following error. Adjusting the various values and seeing what makes it better. (I am no expert)
Also - if you have the accelleration set really low - emc will blend some moves right out.
Anyone with Mesa 5I20 and 7I33 stories? karl1 LinuxCNC (formerly EMC2) 15 12-13-2008 11:28 PM
Spindle Encoder to Mesa 5i20 RogerN LinuxCNC (formerly EMC2) 3 10-17-2008 07:55 AM
HOMING ERROR + MESA 5i20 system TZak LinuxCNC (formerly EMC2) 3 02-18-2008 01:15 PM
HELP to Setup - Mesa 5I20 + Joypad.hal - TZak LinuxCNC (formerly EMC2) 0 02-02-2008 04:43 PM
Mesa 5i20 and EMC daedalus LinuxCNC (formerly EMC2) 6 06-27-2007 02:19 PM
