| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
Hi I want to retrofit an older 4 axis Servo Classic desktop milling machine with EMC2 and Yaskawa 400/200 watt SGDH series drives with matching motors. I plan to use velocity/speed mode with +/- 10 volt analog interface. I need help in deciding what breakout board to use. Any suggestions? Does anyone have any experience in retrofitting these small desktop machines? Am I on the right track with my design/choices? I already own the mill, motors and drives. I will be machining wax, aluminum, and brass. I plan to use the 4th axis on the mill. Looking for any input. |
| I would go with the Mesa board. You need the 5i20 pci board, the 7I33T analog interface and the 7I37T digital interface. http://mesanet.com/ I ended up calling to order. |
| unterhaus, Thanks for the quick reply. Searching CNCZone, the Mesa boards seem to be a popular choice. Any idea how many lines of Gcode are processed per second with a typical setup? Do you know anything that speeds this throughput up?(faster computer, more memory, etc.) I have read that adding a dedicated video card helps EMC2 process faster. Someone today in the Artcam Forum posted a message about Gcode files with over one half million lines(500,000) of code. That is a lot of short moves with a small .002" diameter cutter! |
| with a servo setup, the limitation is your amps/motors/machine. You should be able to keep up with 1GHz computer, no problem. The best setup is at least 500MB of RAM. A dedicated video card is best, if you use one on the motherboard, you run the risk of real time problems. |
I have a similar setup. Very good system. Don't be too cheap on the computer, though. you will find the tuning to be pretty tricky. there are 2 pid loops to deal with. the yaskawa internal one and the EMC2 loop. Yaskawa has setup software in windows so you will need a 2nd computer while tuning. Good luck. |
| Yaskawa CACR-SR | flinty | Servo Motors and Drives | 9 | 04-27-2009 08:11 AM |
| Yaskawa help please | Arty 3000 | Stepper Motors and Drives | 1 | 02-20-2007 10:35 AM |
| Yaskawa P5 to F7 Transition | GuamSK | Phase Converters and VFD | 0 | 02-06-2007 11:19 PM |
| yaskawa help please | h_2_o | Servo Motors and Drives | 12 | 11-19-2006 07:01 PM |
| Yaskawa AC Servo | HillBilly | Servo Motors and Drives | 3 | 10-13-2005 08:21 PM |
