| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
Hello, I'm running a Taig cnc using EMC2. I'm in the process of install my new BOB from cnc4pc, a multifunction board that will control everything. As far as I'm concerned, I think too run my coolant after it's hooked up too my BOB is in each of my files, too place the command for turning coolant on and off. Is m8 correct coding that will work with EMC2 for coolant or is there something I'm missing? Please let me know. -Jason |
| Not sure about EMC, but M7 is usually mist coolant, M8 is flood coolant.
| If you're running the typical ubuntu install this is easy to find. applications > cnc > g code quick reference should open up in the web browser
__________________ Anyone who says "It only goes together one way" has no imagination. |
| M8 is commonly Coolant on, M9 coolant off, but it is what ever the MTB makes it. Al.
| Did some tests. EMC skips m8 and m9 in my file allowing no coolant too turn on or off? What the heck? Coolant is designate too Pin 1 and Pin 1 works because when I set it as E-Stop, and enable/disabled it, the coolant turned on and off. -Jason |
Same as any other text file, a gui for this is still in development unless I'm behind the times. I'm still using hand written configs so take the following fwiw. Look in the emc2/configs/ for the directory created by created by stepconf. In my-mill.ini (if you went with the default name) 2 HALFILES are called, my-mill.hal and custom.hal. According to the readme, custom.hal is for user created commands to prevent stepconf from overwriting. Watch out for conflicts. Hope this helps in some way.
#10
| I'm not sure whats going on. Sorry, was away enjoying the Epic snow of Jackson Hole Wy last week. Anyway, I have gone into Spetconf many times, but I must be skipping something. I still have not figured out why EMC won't read the M8 M9 command. Too Samco, I do not know how too access what you showed ....Noobie here with EMC.-Jason |
#11
| Under the Stepconfig wizard did you try and invert the signal. Its a little check box next to the Pin setup. I want to say its on the second screen before you get the x axis. If I remember correctly it will take it from 0v to 5v. Im learning myself so take the advice with grain of salt. |
| M code for coolant | SIG | Daewoo/Doosan | 5 | 11-29-2007 09:51 PM |
| Common Variables | viorel26 | G-Code Programing | 3 | 10-02-2007 04:09 PM |
| How to control coolant by G code? | Simonetz Tamás | Syil Products | 9 | 09-03-2007 12:44 PM |
| Syil(Spindle, Coolant pump G-code Control Finish) | syil | Product Announcements & Manufacturer News | 4 | 08-27-2006 10:52 AM |
| Common?to Most Surfers | Bear | Fadal | 1 | 01-22-2006 02:13 AM |
