Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 02-13-2008, 07:03 PM
MrWild is on a distinguished road
I'm cheap and looking to save a buck.
Mesa want's $15 for each screw terminal junction block and $15 for each 50 pin cable that runs between the 5120 and 7i33T and 7i37T boards. Are there cheaper sources of T24 terminal blocks and 50 pin cables? When you add up 4 terminal blocks and two cables, that is $90 for what seems like cheap odds and ends. It's kind of obvious where Mesa makes the profits.
Where does a guy go for what looks like $20 worth of parts at the most?
Old 02-13-2008, 07:49 PM
samco is on a distinguished road
the 50 pin cables are the same as what is used for older SCSI drives. Maybe local used computer stores? ebay? Or befriend you local computer guru. As far as the terminal strips.. I don't know.
sam
Old 02-13-2008, 07:53 PM
this
http://www.winfordeng.com/products/brk2x25.php
and
http://www.daqstuff.com/50_pin_breakout_500013.htm
For 50 pin breakout boards.
sam
Old 02-13-2008, 08:16 PM
Holy crap! LOL So the Mesa screw blocks for the 7i33T and 7i37T are deals? Wow. I just threw away some SCSI cables last month too. I do have a friend that may have so e SCSI cables though. Thanks for the info.
Old 02-14-2008, 02:22 PM
Seb Seb is offline
Seb is on a distinguished road
I'm not sure about about the 7i33 and the 7i37, but the Mesa board I'm familiar with alternate signal and ground on their 50-pin ribbon cables. This means you can use twisted-pair ribbons like this one.
Buck MMK 4th Axis Billet Sean Fadal 10 08-14-2009 12:04 PM
Another low buck build. (Yeah, right!) massajamesb Plasma, EDM and other similar machine Project Log 27 10-21-2008 08:07 AM
Bang for buck upgrades ramasule DIY-CNC Router Table Machines 20 02-27-2008 10:50 AM
motor... best bang for my buck eloid CNC Wood Router Project Log 0 03-05-2007 09:04 PM
Buck bucking General CNC (Mill and Lathe) Control Software (NC) 0 11-09-2006 12:50 PM
