Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 02-06-2008, 06:53 AM
waltm is on a distinguished road
New Gecko drive and EMC2
Hi guys,
I'm still early in the building stage of a 3 axis gantry router and would like to use Linux/EMC2 to run it. I have EMC2 installed on a 800MHz P3 to get familiar with.
Gecko is working on some low cost drivers and will be putting a package together that sounds like it's set up for Mach3.
Originally Posted by Mariss Freimanis
OK, how about a 4-axis anodized aluminum box 2" by 2.5" by 4" (50mm by 63mm by 100mm) containing 4 Cheap Drive boards, motors ported to DB-9 connectors, Mach3 ported DB-25 input connector, 3.5mm pitch screw terminal block for non-step related optoisolated Mach3 I/O, short-circuit, reverse polarity and over-temp protection? You attach DB-9 motor cables, parallel port cable and a 15VDC to 50VDC power supply. No wiring at all.
Does it sound like this would easily work with EMC2 or would it be better to use separate drivers with a more standard BOB?
Old 02-06-2008, 07:37 AM
samco is on a distinguished road
as long as you know which pins do what out of the printer port.. Should not be a problem.
sam
Old 02-06-2008, 10:51 AM
Thanks for the reassurance.
I'm reading through old posts but I'm sure I'll have more questions when it comes time to set this up for a machine.
Gecko Drive Problems sandefuj Industrial Hobbies (Support forum) 11 09-05-2007 08:32 PM
Better, cheaper than GECKO drive? cjchands Gecko Drives 13 11-15-2006 04:01 PM
Which Gecko Drive Lloyd Gecko Drives 5 05-31-2006 01:35 AM
Gecko Stepper Drive Box camsoft Gecko Drives 0 05-23-2006 05:34 PM
