| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
HI SETTING UP EMC2 AND HAVE GOTTEN ALL MOTORS RUNNING AND VELOCITY / ACCELARATION SET. HOW WOULD YOU GO ABOUT FINE TUNING THINGS FOR ACCURACY AND REPEATABILITY. I WAS RUNNING MACH AND YOU WERE ABLE TO DO ACCURACY/REPEATABILITY TUNING. I HAVN'T FOUND ANYTHING IN EMC OR DOCS SPECIFICLY POINTING THESE SETTINGS ? ALSO MAY FIGURE THIS OUT BUT HOMING IS GOING THE WRONG DIRECTION REGARDLESS OF TABLE SIZE HOME POSITION SETTINGS. HAVE PIN SET BOTH LIMIT + HOME ? SO FAR SO GOOD THANKS TO ALL. |
| Homing direction is controlled by the velocity value sign. If you want to home in the other direction put a minus sign in front of your homing velocities. For screw compensation see here http://wiki.linuxcnc.org/cgi-bin/emc...w_Compensation If your running at least 2.2.2 just use stepconf to set up your machine. It's on your menu under CNC... John |
| help me in step motor | ibrahem_mo | Mechanical Calculations/Engineering Design | 3 | 09-27-2007 09:47 AM |
| EMC2 - Step/Direction Change Precharge | NightHawk.Eng | LinuxCNC (formerly EMC2) | 3 | 08-13-2007 01:30 PM |
| Need Help With Step Motor Please | simplicity | DIY-CNC Router Table Machines | 3 | 04-27-2007 12:26 PM |
| Step Motor Kit | mamcubus | General Electronics Discussion | 9 | 12-05-2006 11:50 PM |
| Did you see this! 60K RPM Step motor | DennisCNC | CNCzone Club House | 0 | 08-22-2005 03:09 PM |
