01-22-2008, 04:03 PM
Baldor Servo, MicroFlex2, m5i20 and EMC2 | | Hi
I am trying to use EMC2 with the BLAC servo motor from Baldor with the controller MicroFlex2 and have some problems when I try to run it with the G-Codes. The motor has a resolver with 16384 counts/turn, however I've configured the MircoFlex to output "only" 4096 counts/turn.
Currently, I am doing tests with one motor which isn't mounted to any machine. I used SW that came with the MircoFlex (WorkBench) to tune the parameters for Torque and Speed control and I am trying to do a position control with the EMC. I also bought Mesa 5i20 and 7i33 cards so I have a +-10V analog output to the MircoFlex amp, which is connected as single ended input.
Now, I can jog the motor left or right and also control the Jog speed, however when I try to move the motor with the G code, the motor only "jumps" and I get the "joint 0 following error".
What I am doing wrong?
Here is my INI file: Code: # EMC controller parameters for generic controller. Make these what you need
# for your system.
# General note: Comments can either be preceded with a # or ; - either is
# acceptable, although # is in keeping with most linux config files.
# General section -------------------------------------------------------------
[EMC]
# Version of this INI file
VERSION = $Revision: 1.6.4.5 $
# Name of machine, for use with display, etc.
MACHINE = TEST1
# Name of NML file to use, default is emc.nml
NML_FILE = emc.nml
# Debug level, 0 means no messages. See src/emc/nml_int/emcglb.h for others
#DEBUG = 0x00000003
DEBUG = 0x00000007
#DEBUG = 0
# Sections for display options ------------------------------------------------
[DISPLAY]
# Name of display program, e.g., tkemc
#DISPLAY = tkemc
DISPLAY = axis
# Cycle time, in seconds, that display will sleep between polls
CYCLE_TIME = 0.0500
# Path to help file
HELP_FILE = tkemc.txt
# Initial display setting for position, RELATIVE or MACHINE
POSITION_OFFSET = RELATIVE
# Initial display setting for position, COMMANDED or ACTUAL
POSITION_FEEDBACK = ACTUAL
# Highest value that will be allowed for feed override, 1.0 = 100%
MAX_FEED_OVERRIDE = 1.5
# Prefix to be used
PROGRAM_PREFIX = /home/matej/emc2/nc_files
# Introductory graphic
INTRO_TIME = 2
INCREMENTS = 1 0.5 0.1 0.01 0.001
# Task controller section -----------------------------------------------------
[TASK]
# Name of task controller program, e.g., milltask
TASK = milltask
# Cycle time, in seconds, that task controller will sleep between polls
CYCLE_TIME = 0.010
# Part program interpreter section --------------------------------------------
[RS274NGC]
# File containing interpreter variables
PARAMETER_FILE = test1.var
# Motion control section ------------------------------------------------------
[EMCMOT]
EMCMOT = motmod
# Key for real OS shared memory, e.g., for simulated motion
SHMEM_KEY = 101
# Timeout for comm to emcmot, in seconds
COMM_TIMEOUT = 1.0
# Interval between tries to emcmot, in seconds
COMM_WAIT = 0.010
# Base task period, in nanoseconds - this is the fastest thread in the machine
BASE_PERIOD = 50000
# Servo task period, in nanoseconds - will be rounded to an integer multiple
# of BASE_PERIOD
SERVO_PERIOD = 1000000
# Trajectory Planner task period, in nanoseconds - will be rounded to an
# integer multiple of SERVO_PERIOD
TRAJ_PERIOD = 10000000
# Hardware Abstraction Layer section --------------------------------------------------
[HAL]
# The run script first uses halcmd to execute any HALFILE
# files, and then to execute any individual HALCMD commands.
# list of hal config files to run through halcmd
# files are executed in the order in which they appear
HALFILE = core_servo.hal
HALFILE = test1_motion.hal
HALFILE = test1_io.hal
# list of halcmd commands to execute
# commands are executed in the order in which they appear
#HALCMD = save neta
# Trajectory planner section --------------------------------------------------
[TRAJ]
AXES = 1
# COORDINATES = X Y Z R P W
COORDINATES = X
HOME = 0
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 0.1
MAX_VELOCITY = 8.0
DEFAULT_ACCELERATION = 2.0
MAX_ACCELERATION = 3.0
#SCALE = 4096
# Axes sections ---------------------------------------------------------------
# First axis
[AXIS_0]
TYPE = LINEAR
HOME = 0.000
MAX_VELOCITY = 1.0
MAX_ACCELERATION = 1.0
BACKLASH = 0.000
INPUT_SCALE = -4096
#INPUT_SCALE = 491520
MIN_LIMIT = -32.0
MAX_LIMIT = 32.0
FERROR = 1.000
MIN_FERROR = 0.002
HOME_OFFSET = 0.10
HOME_SEARCH_VEL = 0.10
HOME_LATCH_VEL = -0.01
HOME_USE_INDEX = YES
HOME_IGNORE_LIMITS = YES
# PID tuning params
DEADBAND = 0.000015
P = 70.0
I = 1.000
D = 0.000
FF0 = 0.000
FF1 = 0.000
BIAS = 0.000
# Servo related items
OUTPUT_SCALE = 1
OUTPUT_OFFSET = 0.0
MAX_OUTPUT = 1
MIN_OUTPUT = -1
# section for main IO controller parameters -----------------------------------
[EMCIO]
# Name of IO controller program, e.g., io
EMCIO = io
# cycle time, in seconds
CYCLE_TIME = 0.100
# tool table file
TOOL_TABLE = test1.tbl |
