Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 01-18-2008, 04:46 PM
MagooT is on a distinguished road
Automatic probing?
Hello.
I recently started using EMC2 and it seems really neat. However i'm a bit confused about the probing part.
I read about "Z-axis touch plate" for Mach3 and that seems like a really neat trick, could something similar be done in EMC2?
I have experimented a bit with the G38.2 command and it seems to work great for finding the top of stock, however could you add a button or something similar that would probe down and then automatically "touch off" Z? So i would be done automatically without entering the commands manually every time, or does that require modifying the source?
Old 01-18-2008, 06:26 PM
samco is on a distinguished road
take a look at
http://cvs.linuxcnc.org/cgi-bin/cvsw...e=text%2Fplain
There isn't a button per say - but you could create a gcode program that would set your tool length.
sam
Old 01-18-2008, 07:12 PM
Thanks, i have played around a bit with that file, however it doesn't "touch off" the Z (is that even possible to do simply with g-code?), and also it doesn't seem to be possible to probe while the program is paused (for manual toolchange).
That's really what i would like since i have to change tools manually and getting the height right is rather difficult.. any hints how to do this?
Old 01-18-2008, 07:28 PM
that is one of the things some people don't like about emc2. You cannot pause a program and jog/touchoff or such and then unpause the program. If you want to set tool lenghts/touchoff - it will have to be done before the gcode program is run, separate gcode program or within your gcode program.
Or... you can modify emc2.
sam
Old 01-19-2008, 08:46 AM
cyclestart is on a distinguished road
The file samco provided seems to assume a fixture z offset is already in place using some tool as a chosen reference. Then does the other tool offsets by writing to the tool table while the program is active. Am I reading this correctly ?? Very cool if it works as expected. Anyone here tested this?
MagooT
I don't know if a probe type move can write to a fixture offset directly. Maybe after some more coffee.....
edit/ On rereading it looks like the modified tool length is stored temporarily, not in the tool table. emc certainly does some cool tricks!!
Anyone who says "It only goes together one way" has no imagination.
Old 01-19-2008, 11:33 AM
Ok thanks for your replys, i will play around with it some more.
Old 01-19-2008, 11:56 AM
The link I sent - set tool length (best way I would think). There are a few way to do it. I have also done it by setting the g10 (g54..) offsets. It works also but the axis preview is a bit off (shows the cut path is different from the preview path).
dynamically setting the tool length is better as axis will show the preview correctly.
the way I have it setup for circuit board milling is this.
I have a microswitch mouted to the table and every time there is a manual tool change - the gcode program (after I change the bit) goes over to the micrositch and sets its touches off. I then do the math and set the current coordinate system. (again - all in gcode)
The link I set is a better way to do it using tool length.
sam
Edge Probing Rypper Mach Wizards, Macros, & Addons 16 08-06-2009 02:51 AM
Probing with Mach III GuitarEng Mach Mill 3 04-24-2008 03:53 PM
Which Probing System? jimgarner Haas Mills 7 10-30-2007 08:17 PM
Mach and probing KKutt Mach Mill 2 04-22-2007 12:05 PM
Probing geverhart WoodWorking 1 09-03-2004 02:41 PM
