Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 12-27-2007, 10:50 PM
ChandlerBing is on a distinguished road
Realtime implementation in EMC
Hello,
Going through the manuals, it is stated that HAL uses RTAPI for real time implementation. I am intrested to look into how HAL interfaces with real time implementation. What part of code does that and how is it achieved.
Can anyone guide me with some tips, pointers to such things
Kind Regards
Old 12-28-2007, 01:04 PM
unterhaus is on a distinguished road
RTAPI is a wrapper that works with RTAI ( or some older version of rt-linux)
Most people are using RTAI, because rtlinux went commercial and has virtually no support unless you buy the commercial version. If you want to develop your own real-time program, your best bet is to look up RTAI and learn from them. There are a lot of projects that use RTAI. The RTAPI part of emc is very nice, you can check out the emc code from cvs and work through the pieces. Halcmd would be a good place to start.
Old 02-27-2008, 05:28 AM
david_geng is on a distinguished road
I think there was a discussion regarding RTAI vs Xenomai vs rt patch to the kernel. Is EMC considering other two options?
Old 02-27-2008, 04:51 PM
Seb Seb is offline
Seb is on a distinguished road
Jeff Epler tried the -rt kernel in Gutsy Gibbon here. The short of it is it works but latency is a bit worse than RTAI, he was getting about 32 us and concluded that it would probably work if stepgen and/or pwmgen were offloaded onto dedicated hardware (such as a Gecko or a Mesa card).
Old 02-28-2008, 03:26 PM
My impression is that they have the same API, so they are compatible. Haven't heard of anyone that wants to change kernels though.
Optical interupt switch implementation. owhite General Electronics Discussion 26 07-26-2009 04:27 PM
Electrically Insulated QCT Implementation chris59 Mach Lathe 0 01-16-2006 01:28 PM
