| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
Just saw this on the listserver email and I just loaded 2.2.1 last night. Guess I will scrap that one and reload :> Message: 3 Date: Sun, 2 Dec 2007 22:04:43 -0600 From: Jeff Epler <jepler@unpythonic.net> Subject: [Emc-users] Released: EMC 2.2.2 To: emc-users@lists.sourceforge.net, emc-developers@lists.sourceforge.net Message-ID: <20071203040441.GA11634@unpythonic.net> Content-Type: text/plain; charset=us-ascii I'm pleased to announce the next bugfix release of the EMC 2.2 series, version 2.2.2. This version fixes many user-reported problems. The new packages are now available in the package repository. If you already installed 2.2.0 or 2.2.1, this is available as an update. If you are still using 2.1.7 but want to upgrade, instructions are here: http://wiki.linuxcnc.org/cgi-bin/emcinfo.pl?UpdatingTo2.2 CVS users can get this release by checking out the RELEASE_2_2_2 tag. Tarballs will be available on sourceforge.net within the next 24 hours. Changes in this release: * move hal_unlink manpage to development package * make gcode quick reference link into our own full gcode reference instead of the outdated nist document * fix stepconf 'pulley' numbers: the 'motor' and 'leadscrew' fields were transposed * fix stepconf 'charge pump' pin * fix stepconf 'external estop' pin * fix homing in stepconf-created configurations * fix halshow 'watch pin' * restore cone rotation when the A-axis moves * fix 'scara' sample configuration * fix display of home and limit switches on XYZBC machines * improve legibility of running line in text area * additional french documentation translation, including gcode quickref * improve time estimate in gcode File > Properties: it paid no attention to requested feed rates * fix ZX-plane (G18) arcs in the AXIS preview window * fix tripod kinematics example configuration * fix "arc in mdi takes forever" bug (SF#1834576) * fix gcode documentation of toolchange * fix comp311 examples to program Z position * fix stepconf for negative and fractional axis SCALEs * implement M66 E- (read analog value from gcode) * add missing dependency on python2.4-glade * fix problem where metric image-to-gcode would go to the safety height before setting metric units * fix stepconf so that axis doesn't display an 'unknown letter' error when starting a lathe configuration * fix stepconf 'pin 'motion.spindle-speed-in' was already linked' for machines with spindle speed control and spindle feedback * fix stepconf: don't allow arbitrary text to be entered in comboboxes * fix stepconf: coolant pins * stepconf: add parker oem750 timings * fix stepconf: spindle feedback Jeff Epler |
| Cool huh? If your machine is on the internet - you can just go into the update manager and it will show up as an emc2 2.2.2 update. Although if you just downloaded the 2.2.1 live cd - there was a small mistake in the repository for emc2. You need to go into the synaptic package manager. Next go to the menu item settings>repositories. Scroll down to the 2 emc enteries. you need to edit each one to say 2.2 instead of 2.1. now when you go into the update manager - hit Check button - and the 2.2.2 should show up as an update. this will be fixed in the next live cd which will be out in a few days. |
| New release of CeNeCe PRO ver.: 1.10 | DaniSaez | Foam Cutting Software | 12 | 07-17-2008 08:40 AM |
| Electromagnet Release | Zumba | General Electronics Discussion | 12 | 01-06-2008 10:59 PM |
| EMC2 2.2 pre-release information | samco | LinuxCNC (formerly EMC2) | 0 | 10-05-2007 09:22 AM |
| New release of CeNeCe PRO 1.07 | DaniSaez | CNC Wire Foam Cutter Machines | 0 | 11-20-2006 04:49 PM |
| V9.1 SP1 Release for all 9.1 users | cadcam | Mastercam | 14 | 07-09-2003 11:32 AM |
