| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
I'm using EMC 1.0-30 (at least that is the debian pkg version), based on BDI-4.30 I think. I downloaded the sources and rebuilt the modules so it would work with my new Xylotex (i didn't feel like firing up the soldering iron and making a cable or breakout this evening). It works fine, just one problem: at the end of a program after the last instruction, the indicated positions on one or more axes will instantly change to some other value, although nothing actually moves. I think I've ruled out missed steps since the positions is just fine until the end of the program, after the last movement, it gets its position fouled up. This makes it kind of inconvenient to run a program multiple times! Does this have something to do with the home switches? My old home brew driver had the home pins wired closed (i forget if they are active high or low). The xylotex, I think, doesn't do anything with them. I haven't cracked open the xylotex yet because it is new, has a sticker on it to detect if its opened, and I want to let it break in before cracking it open and possibly voiding the warranty. I never had this problem with the old homebrew board. I'm trying to avoid having to do a full OS upgrade, I'm aware there are probably much newer versions out. |
edit/ Oops, the xylotex pinout is a relatively recent emc addition /edit
http://www.mail-archive.com/emc-user.../msg03400.html Homing can be done without home switches. Are you using G92 by any chance. I'm willing to play along at home if you post some code
__________________ Anyone who says "It only goes together one way" has no imagination. Last edited by cyclestart; 12-01-2007 at 08:18 AM. Reason: needed more coffee |
| David, Even if there is a bug in that system, I would be surprised if anyone would be willing to go back and figure out the code to fix it. We are on emc2 version 2.2.1 and that is a lot of water under the bridge. I am with Cyclestart, bite the bullet and upgrade to the current version. Alan
__________________ http://www.alansmachineworks.com |
| Thanks for the tips. I'm downloading the latest BDI ISOs and also the Ubuntu EMC Live CD. I'll give it a try, and assuming no problems, I'll upgrade. I've got enough spare PCs lying around here I can try it first on another. What are the pros and cons of BDI and the ubuntu LiveCD? I am pretty up-to-speed on Debian but have not used Ubuntu yet, although I believe it is derived from debian, right? While searching for tips on-line I gathered there was some kind of a split with the BDI maintainers over GPL terms and access to CVS repositories, so maybe that's why there's a forked project? I'm happy with the xylotex. Sure, I probably could have put together something with equivalent speed on my own, after 6 months of spending weekends messing around with breadboards, ordering parts from different suppliers, making PC boards, etc. I decided it was easier to just shell out. The motors were a bolt-on replacement (I already had NEMA23 pac-sci steppers). I got the 4-axis and I have a rotary table that I will make a stepper mount for next. |
Original EMC was public domain and some people have used it to create proprietary projects. EMC2 is GPL'd. A bunch of the developers were not happy with the idea of someone taking their work for incorporation in proprietary projects and not releasing the source for the modifications. And there were some problems with SourceForge's servers for a while. Complicated I guess.
Alan
| I tried out the ubuntu live CD and I'm very happy with it. I was able to get it working fine of the live CD, so I went ahead and blew away the old BDI install and I'm installing the live CD to the HD now. I see no reason to keep the old version around. The new UI is great of course, and that bug/behavior that started this thread is not present in EMC2. It's like I've been living in a cave the past couple years with old EMC, weak/slow steppers and a wimpy homebrew board that could only do like 1 A/phase. |
| Swiss Lathe, Tool Change Position | John3 | General Metalwork Discussion | 6 | 08-06-2007 06:46 PM |
| How to change Tool change position(About MAZATROL T1 control) | liushuixingyun | Mazak, Mitsubishi, Mazatrol | 5 | 07-07-2007 02:58 PM |
| How to remember the position after close MACH program?? | jimmychand | Mach Software (ArtSoft software) | 1 | 05-25-2007 07:51 AM |
| change offset in program | jianjianca | G-Code Programing | 11 | 12-22-2005 10:48 AM |
| Wizard values can't change? | DennisCNC | Mach Software (ArtSoft software) | 3 | 12-15-2005 07:30 AM |
