Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 11-29-2007, 02:23 AM
djmickyg is on a distinguished road
Install help
I'm having a hard to installing the new EMC live cd...
i am installing on a clean HDD with no other OS on it.
1st I've booted up from the cd and then installed it. once it reboots the load screen just hangs. i have downloaded the iso a few times and from both servers just to make sure i didn't get a dodge copy.
that did work so i downloaded the latest ubunto to install.. that works fine but now I am tring to insall EMC from the cd and there is more trouble
I've downloaded the .sh install file from the linuxcnc site. the terminal opens up. some lines come up and then it closes.. from the linuxcnc site they said the install should come up after this but i get nothing..
i hope this all makes sence? can any one asist me?
Thank Mick
Old 11-29-2007, 10:46 AM
acondit's Avatar
acondit is on a distinguished road
How much memory do you have? I had to install 256mb before I could run the LiveCD install. Before that the install would hang. I did manage to do a text based install with only 128mb.
Alan
http://www.alansmachineworks.com
Old 11-29-2007, 07:24 PM
CarveOne is on a distinguished road
If Ubuntu is already installed on your hard drive and is connected to the internet, go here and follow the instructions at the bottom of the page:
http://www.linuxcnc.org/content/view/21/4/lang,en/
It will tell you step-by-step how to install EMC2 using the dapper-install script after downloading the EMC2 file. It was easy once I found these instructions. I had 256 Mb ram at the time I installed it but added another 512Mb stick since then.
The LiveCD didn't run at all for me.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 11-29-2007, 07:47 PM
One other thing. EMC2 currently is compiled for Ubuntu 6.06 LTS only. If you installed Ubuntu 7.10 Gutsy Gibbon instead of the 6.06 LTS on the LiveCD then EMC2 will need to be recompiled for it. A precompiled version of EMC2 will be released when the next LTS release of Ubuntu is available. Unless you know how to recompile EMC2 for 7.10 the best thing to do is install 6.06 LTS and reinstall EMC2 2.2.1.
CarveOne
CarveOne
Old 11-29-2007, 10:40 PM
thanks for the info..
acondit - I belive i do have more than 256.. the pc did have XP on it before, but i will check that..
Carveone - I have already tried that. the terminal openes up and then downloads the key and all they stuff from them websites that pop up in the list then it closes and nothing else happens.. but i am running the newer 7.10 so that might be why..
Can i download the 6.06 from the ubunto website??
Old 11-29-2007, 11:15 PM
I just found the download on the ubuto site.. i will give that a go and try the manual install.
thanks for your help
Old 11-29-2007, 11:32 PM
wholepair is on a distinguished road
yes you can download 6.06 from the ubuntu website.
http://releases.ubuntu.com/6.06/
The alternate install cd can install in text mode and has other unique features - so if your already decided about reinstalling your system and are going to burn the CD anyway I would get this one - you never know when you might want to put ubuntu on another computer and it will work on the slower low RAM PC's... (just a thought)
BTW - I tried putting EMC2 on 7.10 last night - there are experimental deb files that you run with a dpkg command, the deb files are here on the emc wiki:
http://wiki.linuxcnc.org/cgi-bin/emc...0_Gutsy_Gibbon
I also just found this:
http://www.britishideas.com/2007/11/...-from-scratch/
But with that said I think installing 6.06 lts is the best idea - at some point you have to ask yourself - do you want to play with your CNC - or do you want to play with Linux???
"If you have great talents, industry will improve them; if you have but moderate abilities, industry will supply their deficiency." *Sir Joshua Reynolds (1723 - 1792)
Last edited by wholepair; 11-29-2007 at 11:33 PM. Reason: I dont have to give a reason!
Old 11-29-2007, 11:44 PM
runchman is on a distinguished road
Not that this adds any useful info, but I installed 6.06 LTS a couple nights ago, the 'alternate cd' option, and it worked without a hitch.
EMC installed fine using that script that runs in the shell window...
now I have motors actually turning. don't give up hope, you'll get there !
I had to muddle through a couple errors when emc started up, something with a realtime library not starting, but google searches quickly found the answers.
Keep plugging away at it,
- John
Old 12-01-2007, 01:27 PM
BMG BMG is offline
BMG is on a distinguished road
GO to the Lnuxcnc website and follow directions for installing Ubuntu without EMC2 on it. Then follow the directions for adding EMC2
I had huge problems trying to get the live CD to work and found few sympathetic voices.
When you install it, there is a long line of code just before you execute the install. It ends in something like " quiet splash" or something similar. Remove the "quiet splash".
That will post to the screen all the commands executing and if it hangs again, you can at least figure what commands are being executed when the hang occurs.
I had to add "No Apic" (no idea what it means) at the end of that line of code and it booted right away. Then connected it to a Lan line (it found the internet right off). Using firefox, I got to the Linuxcnc site then finished the EMC2 install.
Good luck
Old 12-02-2007, 08:05 AM
Ive finally gotten it to work!
that you all for your help..
I downloaded 6.06 from the linuxcnc.org site.. and when i ran it, it hung again in the same spot as the EMC installer did, at the point where is says "mounting root file system"
so I tried the extra options thingy (F6) and took out the quiet line and found it was stopping on some controller..
after a bit of googleing this controller and the install stopping on "mounting root file system" I found alot of people also have this issue but it seems everyones cause was slightly different so there was no clear fix for it. but I kept reading people saying make sure you have no USB deivces plugged in during the loading.. which i didn't think I had any untill I realized the front pannel memory card reader would have been usb controlled, so i unplugged it from the motherboard and it worked straight away!!
now i can stop playing with linux and start hooking up these motors.
How to install EMC2 cut more LinuxCNC (formerly EMC2) 11 07-18-2007 08:19 AM
How do you Install more Fans? Regnar Xylotex 1 02-15-2007 08:10 PM
EMC Install jhwatts LinuxCNC (formerly EMC2) 9 01-09-2006 05:36 PM
Install Problem crow TurboCAD/CAM 2 02-18-2005 10:43 AM
Turbo Cad/Cam install help Moondog TurboCAD/CAM 7 07-28-2004 02:07 PM
