| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
I'm having E-stop troubles. I have the E-stop hooked up to pin 10 on my breakout board. In stepconf wizard, on parallel port setup, I have Pin 10 as ESTOP in. Pins 1, 8, 9, 11-16 = unused. Pins 2-7 = x,y,z Pin 17 Charge Pump. In Hal Meter, If I select parport.0.Pin-10-in, status changes from FALSE to TRUE when pressing the E-stop on the mill. parport.0.Pin-10-in-not, status changes from TRUE to FALSE. estop-ext, status changes from FALSE to TRUE estop-out, status does not change. It does however change when pressing the estop icon on the EMC2 main window. estop-out is false when in safe mode I find towards the bottom of my .hal file, net estop-out <= iocontrol.0.user-enable-out net estop-out => iocontrol.0.emc-enable-in I'm just getting things setup currently. Before I go crazy I want some safety first. I know E-stop to software isn't the best method, but it's a start. |
I don't have access to my machine right now, Will check when I get home and post the exact configuration, but you have to connect in the .hal file parport.0.Pin-10-in to iocontrol.0.emc-enable-in This will give the external E-Stop button control.
| there is a command in the .hal file stating net estop-ext <= parport.0.pin-10-in but that was already in there, and not doing what I need. I tried putting something together like you suggested, but when I run the command thru HAL configuration in EMC2, it comes up as an invalid statement. Something is just a little different. |
| I had the same problem. This is how I fixed it. On your .hal file delete this line; net estop-ext <= parport.0.pin-10-in Change line; net estop-out <= iocontrol.0.user-enable-out to read; net estop-out <= parport.0.pin-10-in You should have this now; net estop-out <= parport.0.pin-10-in net estop-out => iocontrol.0.emc-enable-in You need to do this every time you modify the .hal file with the stepconf wizard. Good luck, Jorge |
| Jorge. With those changes, EMC wont' even start. I get the error screen, which I don't fully comprehend just yet. However, you have gotten my closer. There are several lines I've edited so far, and I'll just post all the code for you to look at. Code: # Generated by stepconf at Tue Nov 27 19:39:22 2007 # If you make changes to this file, they will be # overwritten when you run stepconf again loadrt trivkins loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD traj_period_nsec=[EMCMOT]SERVO_PERIOD key=[EMCMOT]SHMEM_KEY num_joints=[TRAJ]AXES loadrt probe_parport loadrt hal_parport cfg=0x378 setp parport.0.reset-time 4000 loadrt stepgen step_type=0,0,0 loadrt charge_pump addf parport.0.read base-thread addf stepgen.make-pulses base-thread addf charge-pump base-thread addf parport.0.write base-thread addf parport.0.reset base-thread addf stepgen.capture-position servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf stepgen.update-freq servo-thread net xdir => parport.0.pin-02-out net xstep => parport.0.pin-03-out setp parport.0.pin-03-out-reset 1 net ydir => parport.0.pin-04-out net ystep => parport.0.pin-05-out setp parport.0.pin-05-out-reset 1 net zdir => parport.0.pin-06-out net zstep => parport.0.pin-07-out setp parport.0.pin-07-out-reset 1 net charge-pump => parport.0.pin-17-out net estop-ext <= parport.0.pin-10-in setp stepgen.0.position-scale [AXIS_0]SCALE setp stepgen.0.steplen 1 setp stepgen.0.stepspace 0 setp stepgen.0.dirhold 35000 setp stepgen.0.dirsetup 16000 setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb net xstep <= stepgen.0.step net xdir <= stepgen.0.dir net xenable axis.0.amp-enable-out => stepgen.0.enable setp stepgen.1.position-scale [AXIS_1]SCALE setp stepgen.1.steplen 1 setp stepgen.1.stepspace 0 setp stepgen.1.dirhold 35000 setp stepgen.1.dirsetup 16000 setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb net ystep <= stepgen.1.step net ydir <= stepgen.1.dir net yenable axis.1.amp-enable-out => stepgen.1.enable setp stepgen.2.position-scale [AXIS_2]SCALE setp stepgen.2.steplen 1 setp stepgen.2.stepspace 0 setp stepgen.2.dirhold 35000 setp stepgen.2.dirsetup 16000 setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb net zstep <= stepgen.2.step net zdir <= stepgen.2.dir net zenable axis.2.amp-enable-out => stepgen.2.enable net estop-out <= parport.0.pin-10-in-not net estop-out => iocontrol.0.emc-enable-in loadusr -W hal_manualtoolchange net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared net estop-out charge-pump.enable <= iocontrol.0.user-enable-out net estop-ext <=parport.0.pin-10-in (stays, but dropped "not" from the end) net estop-out <=parport.0.pin-10-in-not (added "not" to stop conflict with above) Right now, the E-stop is working. When first starting EMC, I do not have to clear the E-Stop on the screen before pressing power. Either the hard E-stop is in or out. However, if I press the software button, it still stops. Press the Hard button, and it stops. Suppose that is good for now. I'm not sure why there is a difference between what works on your system, and mine, I would like to understand though. |
| cnc stop for a saw | cnc metalcraft | WoodWorking | 2 | 09-05-2007 11:58 AM |
| E-Stop | bkukowski | Safety Zone | 47 | 01-09-2007 05:29 PM |
| E-Stop | jhwatts | Xylotex | 1 | 03-10-2006 06:42 PM |
