Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 10-28-2007, 06:11 AM
bbj bbj is offline
bbj is on a distinguished road
Question Diy hardware
Hi there,
I have a 4 axis HobbyCNC board occupying my par port. Is there any other DIY type hardware i can add for additional control through either the serial, i2c or a usb port?
I want to be able to control spindle speed, mist and cutting fluid, and at a later stage a tool changer as well. All of this through a Mini-ITX board.
Regards
John
Old 10-28-2007, 09:13 AM
teamtexas's Avatar
teamtexas is on a distinguished road
I think you can use a breakout board to utilize the unused pins from your current port. It installs between the pc and the driver. Check out the Campbell Designs, he has a nice one with very detailed instructions. By the way, I still haven't got my machine to run yet so take my advice with a grain of salt! I purchased a Ebay driver with next to no support! Some lessons you just have to learn the hard way!!!
Dan
Old 10-28-2007, 05:25 PM
bbj bbj is offline
The thing is, with 4 axis there aint a whole herd or unused pins, esp when you wire up all the limit home and e-stop switches.
Old 10-29-2007, 08:57 AM
Andre' B is on a distinguished road
Some neat looking stuff here.
http://www.ultimarc.com/JShopServer/
Old 10-29-2007, 03:33 PM
samco is on a distinguished road
In emc - you could use the serial control lines as I/O. Remember though this is around +/- 12v signal.
I think the easiest/cheapest would be to buy pci printer port.
sam
Old 10-30-2007, 06:46 PM
blacksmith99 is on a distinguished road
What about MaxStepper from KellyWare? It has the inputs you were talking about.
REgards,
Matt
que tipo de hardware uso?? chenteb Spanish CNCzone 4 02-09-2007 10:03 AM
Toolbox hardware? ZipSnipe WoodWorking 3 11-27-2006 02:29 AM
have the hardware then what... joe aiello DIY-CNC Router Table Machines 1 06-14-2006 02:31 PM
hardware setup servoencoder General CNC (Mill and Lathe) Control Software (NC) 3 04-08-2006 04:39 AM
Hardware Package jhwatts LinuxCNC (formerly EMC2) 10 12-25-2005 10:27 PM
