Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 10-15-2007, 09:39 AM
rmacster is on a distinguished road
Exclamation Setting up EMC
Hi all,
1st post. I have setup a Sieg x2 mill with Xylotec's 3 axis kit (425oz motors) and a CNCFusion ballscrew conversion kit.
I got EMC up and running, and most everything seems to work great.
My only KNOWN problem is that the + and - buttons don't move any axis. The motors move slightly but revert to their original position instantly. I'm thinking that I may have a problem with my microstepping setup. But I am completely guessing.
Also, does anyone have an example of a nice limit switch setup for my type of setup?
Thanks much guys.
Rick McNeely
Old 10-16-2007, 08:43 AM
cyclestart is on a distinguished road
Originally Posted by rmacster View Post
Hi all,
Welcome to the zone Rick. I have the same hardware. Did you purchase the "ready to run" Xylotex kit? If so it should be good to go in 1/8 microstepping.
Hmmm, that's not good. So no movement by any method ?
That's how I do most of my tuning. The emc documentation can be difficult to follow. Would you post the contents of the file "stepper_inch.ini" ?
(Assuming you work in inches). I'm far from an emc expert, but maybe the answer can be found there.
Do you mean the physical mounting of the switches? I have posted the same question in the benchtop mills forum. No replies so far. The way my home switches are currently mounted is very crude. Think 'mechanics wire'.
Anyone who says "It only goes together one way" has no imagination.
Old 10-16-2007, 01:13 PM
Arrow My stepper_inch.ini
The system runs the example file and all axis move like I think they should. I did reverse the x-axis and change the port address. It's only the "Jog" (Correct name?) buttons that don't work. Otherwise the program works well. The setup is difficult. I love linux, but these setup files are typical of old-school Linux setups.
The Xylotex was a "ready to run" system.
Anyway. Thanks for the help. I'm completely new to cnc, and machining for that matter. Lots of fun so far.
Rick
Old 10-16-2007, 05:26 PM
samco is on a distinguished road
I use axis - and the jog keys are the arrow keys for x and y. Page up/down is z.
sam
Old 10-16-2007, 11:12 PM
Sorry, I misinterpreted the original post. It's my special gift.
Our machines are virtual twins. Jogging works fine here, both on-screen button and keyboard using the axis interface. There was some jogging bug in a past release of emc2. Can't remember the exact details, but if you have the latest stable version (1:2.1.7 ?) this shouldn't be the issue.
I'm sure by now you have experimented with the jog speed slider and the incremental/continuous options. The only other thing that comes to mind is differences in our config files.
There's a good chance the developers can suggest a solution quickly. Unfortunately they prefer irc and don't post in these forums very often. Friendly and approachable guys.
Old 10-17-2007, 08:47 AM
Sounds good
I did not know about the keyboard shortcuts for jog. Thanks for that. I will check my version when I get home. That could be an issue. I downloaded the live cd a while ago (Maybe three months?) so maybe I need to get a fresh copy.
If all else fails I'll give IRC a shot.
Thanks guys
Setting z bbergami G-Code Programing 4 10-01-2006 08:21 AM
Setting up VM5 dneisler Visual Mill 6 03-12-2006 09:50 AM
CNC Router setting up the PC KP23 General CNC (Mill and Lathe) Control Software (NC) 0 06-13-2005 01:05 AM
Help With Setting Up My Machine chris69randy DIY-CNC Router Table Machines 4 05-14-2005 09:15 AM
Setting Zero wjbzone TurboCNC 7 01-03-2004 04:25 PM
