Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 10-15-2007, 07:25 AM
Paragon36 is on a distinguished road
EMC Pluto-Step Z / Y axis interference (bug)??
I have just posted the below to IRC #EMC and thought I would seek advice here.
I have a strange situation occuring :-
I have set max feed rate velocity at 900mm/min
When I execute G0 X100 Y100 it moves without error but when I try to return to Y0 I keep getting a joint following error?
If I hit F2 then enter G0 Y0 I get the error again.
Additionaly I get Z: 0.049 from 0.000 and the velocity shows as 7.500 ??
If I then hit F2 then G0 X0 it moves OK
I am using pluto-step with the following setup in the ini file...
Motion Control setup
BASE_PERIOD = 100000
SERVO_PERIOD = 1000000
TRAJ_PERIOD = 10000000
Traj setup
DEFAULT_VELOCITY = 4
MAX_VELOCITY = 15
DEFAULT_ACCELERATION = 5.0
MAX_ACCELERATION = 20.0
Axis Setup for all
MAX_VELOCITY = 15
MAX_ACCELERATION = 5.0
INPUT_SCALE = 1600
FERROR = 0.150
MIN_FERROR = 0.01
Additionaly if I just move with G0 Y100 it gets there but issuing G0 Y0 gives me the same error 'joint 2 following error'
Strange that it shows an error for joint 2 as this would pertain to Axis 2 (Z) right?
I think there is a bug within emc where the Y axis negative move shows as a Z axis positve move...
Just ran HAL scope and monitored Zpos-cmd, Ypos-cmd, Xpos-cmd triggering on 'pluto-step.stepgen.0.counts'
I can see Zpos-cmd and Xpos-cmd at the scope move as commanded but Ypos-cmd is not even displayed!!
Also when commanding Y in the negative plane I see Zpos-cmd changing with a raised step from HAL Scope!!
TIA
SRG
A Axis and Step and Direction Spindle Setup mklb Mach Software (ArtSoft software) 6 11-27-2009 07:19 AM
How to code a step motor axis move? Niggo OpenSource Software 3 08-13-2007 10:40 PM
Pluto-P Friendly BOB epineh LinuxCNC (formerly EMC2) 5 08-05-2007 06:56 PM
CamPod a USB to Parallel Port Three Axis Step Generator Available Dennis Bohlke Product Announcements & Manufacturer News 0 02-21-2006 12:49 PM
Z-axis (ballscrew) step down ratio dowling177 Servo Motors and Drives 1 03-03-2005 10:58 AM
