| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
I have yet to get anything from solidworks running under EMC2. I have successfully gotten a .DXF file from solidworks into MACH3 using both Lazycam and Ace Converter. When I try to use the same .nc file that worked under MACH3 from ACE, EMC2 will spit out a bunch of errors, mainly about no feed rate and some other stuff. It will also not display the part in the viewport. I need a solution, I love EMC2 Compared to MACH3, not because its free but because I feel MACH3 is full of useless buttons, EMC2's interface is much more streamlined.Basically I can get a good .DXF file from Solidworks, but I cannot get any further in terms of GCode that works with EMC2. |
| Just an update, I have become proficient at using Solidworks, Lazycam and MACH3 together and at this point I feel that I could do anything I want with this combination.... But I really want to use EMC2. I have learned to manually set the feedrate with ACE so now I can actually get the file loaded into EMC2... but the downfall I find with ACE is that it does not take into account tool diameter, length etc. If I could get Lazycam to output EMC Compatible GCode I would be in business. |
| Have you checked the EMC web site or mailing list? There are great messages coming every day so I really recommend you to join the list if you're using EMC. I could have forwarded your question, but it would better if you asked it yourself. http://www.linuxcnc.org/ Regards, Sven |
| Basically I have spent time on the EMC IRC channel and talked with some of the people in there including some devs. It seems like they have concluded that EMC is SUPPOSED to work with the GCode format that LazyCam outputs but it is not yet implemented into EMC2. The post processor I am using is the "Mill Example.pst" that is included with LazyCam. I could edit this file and probably get a working code but I am not that experienced as some of you others. |
| I use a GENERIC FANUC post and for the most part it works fine for me. But I'm not using lazycam which seems to be targeted for Mach 3 from a bit of googling.... Don't know how much help you will get for this over in the lazycam forum but it's worth a shot... John |
| EMC2 gcode O-words and parameters | acondit | NCPlot G-Code editor / backplotter | 2 | 07-13-2007 09:47 AM |
| Mach3/EMC2.0 compatible tool setter required | ints99 | Calibration & Measurement | 0 | 04-08-2007 01:47 PM |
| gecko compatible | dgalaxy | Bridgeport and Hardinge Mills | 2 | 06-04-2006 11:28 AM |
| I have a problem with my gcode or my conversion to gcode , everything is tiny? | NickLatech | G-Code Programing | 0 | 03-10-2005 12:46 PM |
| Are CAT and BT compatible? | ETNOM | General Metal Working Machines | 2 | 12-16-2004 07:08 AM |
