Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 09-15-2007, 10:34 PM
babinda01 is on a distinguished road
USB Stick as HDD
Hi
I am trying to set up EMC via the Ubuntu Live install cd, but I am trying to install to a usb key, I am trying this to achieve a solid state hard drive set up. I get 98% through the install but as soon as it starts to install the grub bootloader the install fails with the message that the bootloader can't be installed. Has anyone got any thought on what I should try next???
Regards
Andrew
Old 09-16-2007, 12:32 AM
txcowdog's Avatar
Gold Member
txcowdog is on a distinguished road
I have used a compact flash as a hard drive and it works great.
You just need the adapter which you can pick up for $6 then you attach that to the IDE cable as a master and install away. The system sees the CF card as a regular hard drive. This solution makes for a very quiet system.
Old 09-16-2007, 11:07 AM
buckie555 is on a distinguished road
Thumbs up
txcowdog,
Fantastic idea. I had been thinking about doing something similar myself. Can you point me in the direction of the $6 adaptor you mentioned. Are there any specific procedures you need to go through when installing (i.e. partitioning, etc) or is it just as straightforward as an install to HDD.
Cheers,
Neil
Old 09-16-2007, 11:48 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
$19.95
http://www.acscontrol.com/Merchant2/...CS-CF-IDEToCFA
http://www.google.com/products?q=IDE...lash&scoring=p
Old 09-16-2007, 11:53 AM
Switcher's Avatar
Moderator
I like this setup the best.
http://cgi.ebay.com/Bootable-IDE-to-...QQcmdZViewItem
Old 09-16-2007, 07:05 PM
Thanks for the reply guys. I was originally thinking of using compact flash instead of USB, but I had an 8Gig usb stick handy. I know Centroid/Ajax use a compact flash on their Linux based controls.
I am a little concerned with the number of read/writes I can get out of either a CF or a USB device, Any thoughts?????
Thanks again
Andrew
Old 09-17-2007, 08:58 AM
txcowdog's Avatar
Gold Member
This is where I bought mine:
http://www.buyextras.com/syhiquidetoc1.html
You just plug into the IDE cable and treat it as any other hard drive. My CF was set up from the factory as FAT16 so I deleted the partition, set up a new partition using FAT32 and reformatted. This gave me a little savings on storage by taking advantage of the smaller sector offered by FAT32.
Old 09-17-2007, 09:32 AM
samco is on a distinguished road
I took the emc2 livecd and used these direction to make a persistant live usb drive. (just throwing it out there)
https://wiki.ubuntu.com/LiveUsbPendrivePersistent
sam
Stick Font to GCode Converter MetLHead NCPlot G-Code editor / backplotter 25 07-28-2011 10:58 PM
best paint that hot plastic won't stick to? drcrash Vacuum forming, Thermoforming Etc 6 03-18-2008 06:04 PM
Converting AC/DC Stick Welder to TIG delangecycles Welding, Brazing, Soldering, Sealing 4 06-26-2006 10:53 PM
Ugly Stick PaulH Hobby Discussion 13 10-05-2005 04:00 PM
What's this USB Jog Stick Controller CamSoft has? Bob Pierre CamSoft Products 1 01-08-2004 10:27 AM
