Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 09-08-2007, 08:27 AM
Big John T is on a distinguished road
Using a 5 1/4 Floppy Stepper and Board
What I want to do is use a 5 1/4 floppy driver board with the floppy stepper and run it with EMC2. This is for practice so no negative vibes on the size.
I want to hook it up to the parallel port.
The pin outs are as follows on the floppy controller.
Pin 20 > Step
Pin 19 > Ground
Pin 18 > Direction
Pin 17 > Ground
The floppy info that I have found says it needs to be pulled low to step.
Can I just short pins 19 and 20 to see a step after hooking up the power?
The connections to the parallel cable are they just a straight connection between the parallel port and the floppy?
John
Old 09-08-2007, 02:58 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
Can't answer your question directly - but you might check out this guy - he's done it!
http://www.nhcad.com/flpystpr/index.html
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
board now move stepper .. problem fix suwat Hobbycnc (Products) 0 08-11-2007 10:50 AM
5 1/4 Floppy drive Stepper Motors High Seas Stepper Motors and Drives 9 03-17-2006 02:33 AM
Help ID this stepper board h_2_o CNCzone Club House 3 10-07-2005 03:48 AM
3.5" floppy, 2-phase bipolar stepper. Levitan General Electronics Discussion 2 03-21-2005 10:32 AM
Fun with floppy stepper and driver Konstantin General Electronics Discussion 5 03-08-2004 01:18 AM
