Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 09-07-2007, 03:34 PM
Gold Member
heilcnc is on a distinguished road
spindle encoder
i just started using emc2(its a little hard to set up but when done works great) on my mill now i want to try it on my lathe i use turbocnc now with a 1ppr encoder on the spindle for threading can i use the same setup with emc2 or do i need more pprs thanks
Old 09-10-2007, 09:12 AM
cradek is on a distinguished road
Lathe spindle encoder
You need more than one ppr. This has been discussed a lot on the emc-users mailing list; here is one post I found about it: http://article.gmane.org/gmane.linux...emc.user/2575/
Spindle Encoder to Mesa 5i20 RogerN LinuxCNC (formerly EMC2) 3 10-17-2008 07:55 AM
QT-28N spindle motor control encoder problem Fred Raud Mazak, Mitsubishi, Mazatrol 10 12-10-2007 04:28 PM
How do I orient spindle after encoder replacement? Torq Cut 22 vettespeed Bridgeport and Hardinge Mills 8 01-22-2007 01:39 PM
Spindle speed controler and encoder Parameter Mach Software (ArtSoft software) 1 12-10-2005 06:30 PM
