| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
I am at the stage where I want to create a Break Out Board to plug my Pluto-P board into, my thinking is to actually make 3 boards, one input board for things like E-stops, limits and homing switch's, one board for outputs spindle, vacuum clamp etc, and one board for the encoder inputs and PWM signals. I am thinking of the BOB's to be straight thru, and will put opto's on the add-on boards - H-bridges , Input and Output. I plan to mount all of this together, spaced with plastic stand off's to make termination easier and neater. The reason I want three seperate boards is to take one ribbon cable from each header of the Pluto directly to the respective board, is this reasonable thinking or am I being stupid ? Any suggestions for improvement? I can fabricate PCB's easily at home so I can try a few different methods. Cheers. Russell. |
| Russell, How about creating a BOB with a set of holes that match the Pluto-P and mounting header pins on Pluto-P and header sockets on the BOB (or vice-versa) so that your Pluto mounts like a daughter board to the BOB? Then you could just come off of the BOB with whatever outputs or inputs were appropriate. You could mount a 26 pin idc double row pin connector to take a short 26pin to DB25 ribbon cable from the BOB to the Pluto and a DB25 connector into the BOB to be connected to the Pluto through your opto-isolators. Is this all clear as mud? Alan
__________________ http://www.alansmachineworks.com |
| Great idea Alan, I take it you mean bring the parallel cable straight into the BOB, through opto's, then up to the pluto via a DB25 ribbon, with the Pluto plugging in to the BOB, that would be pretty neat. I have read something about not using opto's for the parallel port side of things with the bi-directional mode of parallel port that the the Pluto uses, but that could easily be left out, and I can still use the DB25 on the Pluto for the cable input. I do like the idea of plugging the Pluto straight onto the BOB and think I will run with that, now I have to work out the measurements so the two align, can I use a hammer to "adjust" for any errors ? ...lol Thanks again , Russell. |
| Russell, I am interested in how it turns out. I have a few small servo motors and have been thinking about getting a Pluto-P myself. Have you already got your design for the H-Bridge? Alan
| For the H-bridge I am being a bit lazy as I have a friend who is designing one for his machines, which are more commercially based routers. I am going to "help" him by using my machine as the guinea pig. I will get his design and build it at home. I was going to use Samco's boards as they seem quite good, but I think the components he used are too hard to locate here in Australia (same old story). He has posted them and links on my router build log : http://www.cnczone.com/forums/showthread.php?t=22101 Look at the end of the log, he has listed them there. Lol I just checked and you have already posted there so I guess you know about his boards ![]() Cheers. Russell. |
| Yes, I have seen Sam's H-bridge. My problem is that I just don't know enough about H-bridges to evaluate what is good and what is not. I hate to spend a bunch of money and be dissatisfied. I have downloaded a few pdfs on H-bridges, so I guess I need to actually read them now. I guess for a start I'll create a BOM and see where I can find the parts and what they cost. Alan
| EMC2 -- Pluto Servo -- Need Help | TZak | LinuxCNC (formerly EMC2) | 4 | 03-02-2007 01:54 PM |
| Tormach and Gecko a friendly debate | Mariss Freimanis | General Electronics Discussion | 18 | 08-26-2005 09:33 AM |
| Tormach and Gecko a friendly debate | Tormach | General Electronics Discussion | 7 | 08-26-2005 07:20 AM |
