Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 06-20-2007, 08:53 PM
RogerN is on a distinguished road
Spindle Encoder to Mesa 5i20
I have my encoder connected and it shows counts on the Axis HAL configuration window. I took the info from nist-lathe and pluto-lathe and added the lines to the end of my m5i20 motion hal file. When I run the application, I get:
hal error signal 'spindle-index-enable' already has output or I/O pin(s)
From nist-lathe:
# hook up motion controller's spindle indexing pin
newsig spindle-index-enable bit
linkps motion.spindle-index-enable <=> spindle-index-enable
linksp spindle-index-enable <=> counter.0.index-enable
From lathe-pluto:
linksp spindle-index-enable <=> pluto-servo.encoder-2-index-enable
My m5i20 motion addition:
linksp spindle-index-enable <=> m5i20.0.enc-03-index
Any ideas on what I'm doing wrong?
Thanks!
Roger Neal
Old 06-21-2007, 09:43 AM
samco is on a distinguished road
did you see this on the user list?
The last line should be:
linksp spindle-index-enable <=> m5i20.0.enc-03-latch-index
Its confusing that the 2.1.x version of the 5i20 driver doesn't
use the same naming convention as the other drivers. What
most drivers call "index-enable", it calls "latch-index".
I'm not 100% sure that indexing works correctly in the 2.1.x
version of the 5i20 driver. But "halcmd show pin *index*" shows
"latch-index" as the only bidirectional pin on the 5i20 encoder.
Regards,
John Kasunich
Old 06-21-2007, 11:24 AM
John, I used the latch-index instead of index and it did get rid of the error in trying to run emc2. I tried the G76 canned threading cycle in the example files. The cycle ran cutting air but the z speed didn't slow down or speed up with the spindle. I think the example program was set for 20tpi, I was probably cutting 1 to 5 tpi (guess, my air thread guage isn't real accurate :-). I actually stopped the spindle and it still threaded at the same speed.
Since the index works on other hardware, could I just use a m5i20 spare input for the index pulse?
Or could this be configured for a unidirectional spindle index pulse? (I don't understand how EMC2 uses the spindle-index-enable bidirectionaly.
Thanks!
Roger
Old 10-17-2008, 07:55 AM
visky is on a distinguished road
linksp spindle-index-enable <=> m5i20.0.enc-05-latch-index
I wrote this into 5i20_motion.hal file and get error message:
Can not link"m5i20.0.enc-05"
What i am doing wrong? Do i have to write any additional code for spindle index?
I would like to use input pins for Y axis-> 05,06,07 input pins from P3 conector.
Also, if i add this code ( from ninst-lathe ) for spindle feedback :
# I/O thru the parport
loadrt hal_parport cfg="0x0378"
# counting the spindle counter in software
loadrt counter num_chan=1
# misc blocks needed to do fun things
loadrt ddt count=6
# spindle speed feedback
loadrt lowpass count=1
loadrt mult2 count=1
loadrt scale count=1
# first we read parport inputs
addf parport.0.read base-thread
# update counter
addf counter.update-counters base-thread
# differentiators to make vel and acc signals
addf ddt.0 servo-thread
addf ddt.1 servo-thread
addf ddt.2 servo-thread
addf ddt.3 servo-thread
addf ddt.4 servo-thread
addf ddt.5 servo-thread
addf lowpass.0 servo-thread
addf mult2.0 servo-thread
# Spindle speed feedback -- spindle-speed-fb-rpm can be metered or scoped
# but beware that at the highest speeds the software-based counter cannot
# keep up, and the speed is estimated incorrectly
newsig spindle-speed-fb-raw float
newsig spindle-speed-fb-filtered float
newsig spindle-speed-fb-rpm float
# The gain of the lowpass filter is a trade-off: Higher numbers track spindle
# speed better when the speed changes. Lower numbers give a more steady
# estimate of average spindle speed when the speed is nominally constant
setp lowpass.0.gain 0.01
linkps counter.0.velocity => spindle-speed-fb-raw
linksp spindle-speed-fb-raw => lowpass.0.in
linkps lowpass.0.out => spindle-speed-fb-filtered
setp mult2.0.in0 60
linksp spindle-speed-fb-filtered mult2.0.in1
linkps mult2.0.out spindle-speed-fb-rpm
newsig spindle-phase-Z bit
linksp spindle-phase-Z => counter.0.phase-Z
linkps parport.0.pin-13-in => spindle-phase-Z
setp counter.0.position-scale 1024
# report our revolution count to the motion controller
newsig spindle-pos float
linkps counter.0.position => spindle-pos
linksp spindle-pos => motion.spindle-revs
will it count?
I will run my VFD with 0-10Volt .
How can i solve my problem?
Bridgeport Torq Cut 22 - Spindle/encoder problems, bad? vettespeed Bridgeport and Hardinge Mills 11 07-28-2011 04:16 AM
How do I orient spindle after encoder replacement? Torq Cut 22 vettespeed Bridgeport and Hardinge Mills 8 01-22-2007 01:39 PM
Spindle speed controler and encoder Parameter Mach Software (ArtSoft software) 1 12-10-2005 06:30 PM
