| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
| I still didn't decided which one is beter. Why? If i install Mach 3 on Pentium III 1Ghz i get 35000Hz .This i read from manual.So ,if i will have encoder with 4000pulses per revolution this will give me 0,0025mm resolution.I have ball screws pitch 10mm/revolution and gear reduction 2,5:1 After calculation (35000/(4000*2,5)=3,5 ) and multiply this by 10 i get 35mm/s or 2100mm/min From this i would have max rapid speed 525 rev/min of max possible 3000!! Thats nothing. Now,how it's with EMC ? Will i have more than 35000Hz (pulses/second)? P.S i will use Celeron 500Mhz procesor |
| A) mach doesn't do encoders.. see note 1 2) Your pulse rate depends on the computer. I was getting 50k base threads on a 600mhz pentium 3 - IIRC that was pushing it. (the computer gets sluggish the faster you try to push it.) This means - either you could run steppers at 25khz (base thread/2) or you could read encoders at near the base thread speed (near 50k) now if you get external hardware - you could count encoders much much faster than that. you can look at my thread where I started looking at using just the printer port to run servos. - it is very doable. http://www.cnczone.com/forums/showthread.php?t=25929 The real question is - do you mean 'encoder' or 'stepper'.. Or maybe 'what are you trying to do' Note 1. mach needs external hardware like geckos to run servos. Mach is really a step and direction program. (This is a broad statement - others should expand on it as I have no experience with it) |
| I will use servo motors with rotary encoders. Rutex servo drive C10 bidirectional breakout board from cnc4pc.com Where are actualy limitets: for outputs from PC or inputs to PC? If i would have to buy an external hardware for much highter resolution give me a link of manufacturer |
| Mach 2/3 | nev25 | Mach Software (ArtSoft software) | 10 | 08-30-2007 04:50 PM |
| Confused: Mach Turn, Mach Mill, Mach 2/3 ? | CanSir | Mach Software (ArtSoft software) | 5 | 02-16-2007 04:41 AM |
| Mach 3 no spindle - but OK in Mach 2 | zcases | Mach Software (ArtSoft software) | 9 | 07-31-2006 07:38 AM |
| Moving to mach 3 need exact mach 2 screen | carlnpa | Mach Software (ArtSoft software) | 2 | 12-11-2005 03:00 PM |
| will mach 2 or mach 3 work for 4 axis cnc? | Runner4404spd | Mach Mill | 3 | 10-05-2005 11:44 AM |
