| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
Hi, I'm new to EMC2 and have a problem. I don't understand how I can use a subroutine in the g-code supported by EMC. What I am trying to do is grind a part which is mounted vertically on a rotary table ('C' axis) and I want to grind a diameter, step down nearly the width of the grinding wheel and repeat the grinding to diameter a number of times (there is a good reason for wanting to do it this way rather than turning the diameters!). So, what I would like to create is a subroutine which would take care of the grinding to diameter part (and preferably be able to accept different final diameters). Reading the EMC2 documentation I guess that G81 wouldn't do but that some form of 'O' routine might - the only problem is that I don't understand how the 'O' routine is supposed to work or how it is called from the main program - other documentation seems to suggest G98 but this doesn't seem to be supported by EMC2. Can anyone offer (simplified) words of wisdom please? Thanks, Ian |
Try something like this: % (SUBROUTINE EXAMPLE) o100 sub G02 X-.5 Y-0 I-.5 J0 G02 X.5 Y-0 I.5 J0 o100 endsub G54 G01 X.5 Y0 Z1. F50. G1 Z-.25 o100 call G1 z-.5 o100 call G1 z-.75 o100 call G0 Z1. M30 % Notice that I put the subroutine at the top of the program. I read in the user's manual (page 153) that subs had to preceed the code that calls them. I hope this helps you out. Dan |
EMC2 does support G98, at least with code G81. Just loaded a drill program to double check. Not sure if there is a problem with G98/G99 with other canned cycles. Maybe the problem is with the height of the initial approach movement or the use of G90/G91 ? Edit/ Took the time to read the post more closely. This isn't a job for a canned cycle. Last edited by cyclestart; 06-10-2007 at 04:57 PM. |
| Thanks, I did find a bit more in the EMC WIKI and made a script as below.. % #1 = 0.2 (finished diameter) #2 = 0.05 (feed step size) #3 = 1 (total depth) #4 = 0.1 (safe X) #5 = 1.4 (stock diameter) #6 = 0.5 (grinding disk thickness) #7=#6 #8 = [[[#5-#1]/2]/#2] (no. of turns of A axis to final diameter) #9 = [#3/#6]+1 (no. of steps down to finished depth) #10 = [#3/#9] (step size) #11 = 0 (counter) o100 do G0 Z[0 - #10] G0 A[#8*360] X[[[#5] - [#1]] /2] G0 X[#4] #11 = [[#11] + 1] o100 while [[ #11 * #10] LT #3] o200 sub G0 Y5.0 G0 X-0.565 G1 Y-5.0 F 3.0 G0 A180 G1 Y5.0 F3.0 G0 Y0.000 G1 A180 F15 o200 endsub N001 G21 G90 G40 G49 N002 o100 call [0.20] [0.04] [1.00] N003 o100 call [0.27] [0.05] [2.00] N004 G0 Z-3.3 N005 o200 call N006 G0 Z-3.8 N007 o200 call N008 G0 X0.1 N009 G0 Z-3.47 N010 o100 call [0.27] [0.05] [2.74] N011 M0 N012 G0 Z-6.23 N013 o200 call N014 o100 call [0.20] [0.04] [1.00] N015 o100 call [0.1] [0.04] [0.5] N016 G0 X40 % I do have a problem with this, however, that I can't understand.. When I try to load it into EMC2, I get an error message saying 'Bad character near line 34' - this appears to be the line numbered N002 - the first subroutine call. I copied the format of this line directly from the WIKI and I've looked at it many times without seeing the problem - any ideas? Thanks, Ian |
| There might be a problem with your use of the while loop. That program tries to load here in axis but seems to get caught in some type of infinite loop. Probably it either it doesn't have a break or can't reach it. My best guess being not much of a script writer. I've written a few parametrics but not with the type of loops and conditionals found in the wiki. |
o100 sub [1] [2] [3] (#1 = 0.2) (finished diameter) (#2 = 0.05) (feed step size) (#3 = 1) (total depth) #4 = 0.1 (safe X) #5 = 1.4 (stock diameter) #6 = 0.5 (grinding disk thickness) #7=#6 #8 = [[[#5-#1]/2]/#2] (no. of turns of A axis to final diameter) #9 = [#3/#6]+1 (no. of steps down to finished depth) #10 = [#3/#9] (step size) #11 = 0 (counter) o101 do G0 Z[0 - #10] G0 A[#8*360] X[[[#5] - [#1]] /2] G0 X[#4] #11 = [[#11] + 1] o101 while [[ #11 * #10] LT #3] o100 endsub o200 sub G0 Y5.0 G0 X-0.565 G1 Y-5.0 F 3.0 G0 A180 G1 Y5.0 F3.0 G0 Y0.000 G1 A180 F15 o200 endsub N001 G21 G90 G40 G49 N002 o100 call [0.20] [0.04] [1.00] N003 o100 call [0.27] [0.05] [2.00] N004 G0 Z-3.3 N005 o200 call N006 G0 Z-3.8 N007 o200 call N008 G0 X0.1 N009 G0 Z-3.47 N010 o100 call [0.27] [0.05] [2.74] N011 M0 N012 G0 Z-6.23 N013 o200 call N014 o100 call [0.20] [0.04] [1.00] N015 o100 call [0.1] [0.04] [0.5] N016 G0 X40 % I made a couple of changes in your code. It still has a problem that I haven't taken the time to fix. It is reporting a divide by zero error in line 11. You hadn't specified O100 as a subroutine. So I changed your do while loop to O101 and wrapped it in a O100 sub -- endsub pair. You specified three parameters in your calling sequence, but didn't specify the formal parameters in the sub routine. I moved the variables 1 thru 11 inside the subroutine and I commented out #1, #2 and #3 since they are passed in to the subroutine. If they are needed, you need to change them so they don't conflict with the parameters that are passed in at the call. Alan
__________________ http://www.alansmachineworks.com |
#10
| This thread was an eye opener for me. Like a 2 year old with a newly learned word, just can't resist trying to show off. **while the more senior members snicker no doubt** ![]() As I haven't quite grasped what you're doing, I expanded on Dan Falck's post. The way I would have done this orginally Code: % #100= 1000 (RPM) #101= 1 (CIRCLE RADIUS) #102= .375 (CUTTER RADIUS) #103= 30 (FEED) #104= 2 (X CENTER) #105= 2 (Y CENTER) #106= -.25 (DEPTH) o100 sub #107= [#101+#102] (PATH OF CUTTER) G00 X#104 Y[[2*#102]+[#107+#105]] G01 Z#106 F#103 G03 X#104 Y[#107+#105] R#102 G02 X[#107+#104] Y#105 R#107 X#104 Y[[-1*#107]+#105] R#107 X[[-1*#107]+#104] Y#105 R#107 X#104 Y[#107+#105] R#107 G03 X#104 Y[[2*#102]+[#107+#105]] R#102 o100 endsub S#100 M03 G54 G00 X#104 Y[[2*#102]+[#107+#105]] Z.1 o100 call #101=.8 o100 call #106=-.5 #101=1 o100 call #101=.8 o100 call G00 Z2 M02 % Code: % ([1=first_cut.r] [2=cutter.r] [3=feed] [4=x center] [5=y center] [6=depth] [7=stepover] [8=finish.r]) o100 sub o101 while [#8 LE #1] #10= [#1+#2] (PATH OF CUTTER) G00 X#4 Y[[2*#2]+[#10+#5]] G01 Z#6 F#3 G03 X#4 Y[#10+#5] R#2 G02 X[#10+#4] Y#5 R#10 X#4 Y[[-1*#10]+#5] R#10 X[[-1*#10]+#4] Y#5 R#10 X#4 Y[#10+#5] R#10 G03 X#4 Y[[2*#2]+[#10+#5]] R#2 #1=[#1-#7] o101 endwhile o100 endsub S1000 M03 G00 Z1 o100 call [1] [.375] [30] [0] [0] [-.25] [.1] [.8] o100 call [1] [.375] [30] [0] [0] [-.5] [.1] [.6] G00 Z2 M02 % Maybe there's something you can use in above somehow. |
| Calling a subprogram that has subroutines | Shizzlemah | Fadal | 6 | 03-25-2007 09:04 PM |
| Oi subroutines help | mishikwest | Fanuc | 1 | 08-01-2006 05:17 PM |
| Fanuc 15m Subroutines | BROCD | Fanuc | 11 | 02-27-2006 07:04 AM |
| Subroutines in Mill Master Pro | truline | G-Code Programing | 0 | 10-08-2005 12:37 AM |
