Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 04-21-2007, 10:34 PM
nancygal is on a distinguished road
EMC for Feisty Fawn
I just downloaded and installed Ubuntu 7.04 (Feisty Fawn). It is the only version of Ubuntu that I have been able to connect to the internet with on this computer. I would like to play with EMC on this computer but it is only supported with Ubuntu 6.06 (Dapper Drake). Any ideas on how to use EMC with 7.04?
Old 04-22-2007, 06:41 AM
epineh is on a distinguished road
Did you disable ipv6 on you 6.06 version ?
Took a little searching but I got there in the end.
For details, have a look here :
http://www.cnczone.com/forums/showthread.php?t=35705
The browsing was easy, getting synaptic to work took a little more effort, but was nice once it was all going. I was impressed I could get a browser working with a live version running, even before any HDD install.
I liked it so much I am in the process of upgrading all home PC's to Ubuntu, I had tried Linux previously a few years back but it wasn't really "there" for desktop use for me, now I am quite happy with it and intend to use it exclusively.
Good Luck!!!
Russell.
Old 04-22-2007, 04:23 PM
I would prefer to use 7.04 as 6.06 didn't work on this computer. This system has a Intel Core 2 Duo processor. An old Dell system I have works with 6.06 but it is not connected to anything.
Old 04-22-2007, 05:01 PM
CountZero is on a distinguished road
I have just installed 7.04, and it runs great on my system. That being said, I don't really see why 6.06 couldn't be made to work with your computer. Perhaps dualboot with 7.04 if not doing CNC stuff..
Old 05-01-2007, 07:26 PM
NGinuity is on a distinguished road
I got EMC to run just fine on Feisty.
Old 05-01-2007, 10:43 PM
How?
Old 05-01-2007, 11:05 PM
Did you just try to install the precompiled package?
I compiled the app itself from source. Theres a ton of prerequisites you must install first, and it appears that the build from source instructions for 6.10 work for this too. The wiki over at linuxcnc.org has a good article on it, but the easiest way to bring your system up to speed on the prerequisites is running apt-get, here is the entire command:
Code:
 $ sudo apt-get install cvs build-essential libgtk2.0-dev libgnomeprintui2.2-dev \
    tk8.4-dev python2.4-dev python-numarray-ext python2.4-imaging \
    libpth-dev bwidget xlibmesa-gl-dev libgl1-mesa-dev libglu-dev \
    libreadline-dev libxmu-dev python-tk
Then you just download the source code from CVS, compile it, and run it. If you need asistance with complications, just let me know. There were a couple of tweaks I had to make, and I don't remember what they were offhand (it was 2 AM), but I got it to run.
Old 05-02-2007, 09:38 AM
samco is on a distinguished road
With this - I don't think you have installed the realtime kernel. I think your just running emc in sim mode.
You can try the rtai latency test
sudo mkdir /dev/rtf; sudo mknod /dev/rtf/3 c 150 3;
sudo mknod /dev/rtf3 c 150 3;
cd /usr/realtime*/testsuite/kern/latency; ./run
should look like this.
Code:
ubuntu:/usr/realtime-2.6.12-magma/testsuite/kern/latency$ ./run
* Type ^C to stop this application.
## RTAI latency calibration tool ##
# period = 100000 (ns)
# avrgtime = 1 (s)
# do not use the FPU
# start the timer
# timer_mode is oneshot
RTAI Testsuite - KERNEL latency (all data in nanoseconds)
RTH|    lat min|    ovl min|    lat avg|    lat max|    ovl max|   overruns
RTD|      -1571|      -1571|       1622|       8446|       8446|          0
RTD|      -1558|      -1571|       1607|       7704|       8446|          0
RTD|      -1568|      -1571|       1640|       7359|       8446|          0
RTD|      -1568|      -1571|       1653|       7594|       8446|          0
RTD|      -1568|      -1571|       1640|      10636|      10636|          0
Code:
Old 05-02-2007, 09:41 AM
btw - the reason the emc2 group chose dapper.
2.1. Why aren't there packages for Ubuntu 6.10 "Edgy Eft"?
We have chosen to use 6.06 because it's a "long term support" (LTS) release. If you use it, you can be sure of support and security fixes from the Ubuntu team for 3-5 years. However, we would be happy to accept and host packages for 6.10 if a user/developer of emc2 wishes to contribute them.
Old 05-02-2007, 10:31 AM
Samco....I'm quite sure my installation is the realtime kernel :-)
Anyway, I can go home and do it from scratch again, and do a step by step with 7.04 if youd like?? It's running on a test box, so it really wouldn't be a big deal if I did.
  #11   Ban this user!
Old 05-02-2007, 10:35 AM
That would be great - an addition to the wiki would be even better
thanks
sam
  #12   Ban this user!
Old 05-02-2007, 10:41 AM
I will make it so.
