Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 03-27-2004, 12:23 AM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
BDI Linux
Has any one heard of BDI a lunux control program for CNC machines?
Apparently it is a way to install a controller for rutex and gecko drivers. Even though it is linux, you dont need to have linux installed on your computer. Apparently the name BDI is short for brain dead install. I gather you just boot your computer from the CD and it does all the rest.
I have heard that Mach2 is a windows copy of this program. The only difference is it is for free.
I have ordered the CD because I cant download 500meg thorugh my modem.
If all this is true then you get the best of both worlds. An efficient free program, and you get to keep wondows on your computer too.
I will post further information when I get the CD.
Here is the site. http://www.linuxcnc.org
Old 03-27-2004, 03:59 AM
svenakela is on a distinguished road
Well, the BDI will install Linux for you, it's a Linux installation.
Sven
Old 03-27-2004, 06:14 AM
ynneb's Avatar
Moderator
Yes but it more than just linux, it is a CNC program that runs under Linux.
Old 03-27-2004, 09:46 AM
ToyMaker's Avatar
ToyMaker is on a distinguished road
and the CNC program is EMC (Enhanced Machine Control) created by NIST (National Institute of Science and Technology).
I think the bdi image (for download) and cd are available at LinuxCNC
robotic regards,
Tom
"What's the difference between a near sighted hunter and a constipated owl?"
One shoots and shoots and can't hit;
the other hoots and hoots and can't ...
Old 03-27-2004, 05:35 PM
ynneb's Avatar
Moderator
Ok, but what I was wondering is, does any one use it, and is it any good?
Is it worth the hassle of the big download, or is it some home hack peice of software that will be a waste of time? Any comments from users would be appreciated.
Old 03-27-2004, 07:59 PM
NeoMoses's Avatar
NeoMoses is on a distinguished road
If you've never used Linux of UNIX, you'll likely be in for a bit of learning. If this is your first time installing Linux, don't try to dual boot with a windows operating system, it can be tricky and you might lose the ability to boot into windows if you set it up incorrectly.
EMC is a very capable CNC control program. The reason it's not more popular is the whole need to run Linux.
My name is Electric Nachos. Sorry to impose, but I am the ocean.
http://www.bryanpryor.com
Old 03-27-2004, 09:11 PM
Urgundiz is on a distinguished road
I've downloaded it and the BDI is really a BDI (next, next, next..). My only issue is that the iso is not self bootable, at least in my year 95 p266 but you only need to create a linux boot diskette the usual way.
Just now I am figthing with the emc.ini file, seems pretty capable, but I expect a pair or three hours of tweaking (btw, as usual..)
Will keep you informed.
/U
Old 03-27-2004, 10:21 PM
ynneb's Avatar
Moderator
I have a program called Lindows. It is a linux version of windows. You set the computer to boot from a CD drive and insert the Lindows disk. The computer boots from the CD and launches what looks very similar to an XP setup. I think I will use this and try to run the EMC program from this sort of setup. That way It wont mess with my current windows files.
Urgundiz it would be great if you could keep us up to date with you progress etc.
I really want to push through this Linux barrier and see how well EMC works. I hope to make further postings that will advise others how to take this same path without making the same mistakes along the way.
Old 03-27-2004, 10:25 PM
Stevie is on a distinguished road
I had Linux and it was ok; I used it for a few weeks; then I tied to install something; man what a pain; I never did get anything installed; I finally reformated the HHD and now its slave to this ne
Old 03-28-2004, 05:13 AM
To have EMC work properly you need Real Time Linux, which is a kernel update and therefore almost all Linux distributions needs an update. The RT part is there to ensure that the input reading speed is high enough, it also makes EMC running perfect at really high speeds with old PC's.
I haven't been using EMC yet for real, but as my router becomes ready that's my natural choice.
Linux has a higher learning level and it takes some time to get into it but when you've learned you'll realize that it's not an ordinary Point-n-Click OS, it's simply the only thing you need.
Regards,
Sven
  #11   Ban this user!
Old 03-28-2004, 06:23 AM
kong is on a distinguished road
The BDI version comes packaged with the pre-patched real-time kernel, so you won't need the real time linux patch. i spent several days trying this software out before christmas, but just couldn't get it to work properly. I ended up purchasing Mach2. However, I do not intend to put you off, many people have had great success with the software, just don't spend too long trying to get it to work! Good luck.
Old 03-28-2004, 06:59 AM
ynneb's Avatar
Moderator
I have wimped out and taken the tried and beaten path of buying Mach 2.
Sorry to start this thread and then bonb out badly by purchasing Mach 2.
I am just too new to this whole thing to have to worry about any more dificulties of having to deal with Linux too.
I hope someone gets it up and running and then publishes a detailed document of what they did and their sucesses.
Now I am feeking a bit red faced.
New help needed PLZ !! BDI Linux k-linkz LinuxCNC (formerly EMC2) 1 03-18-2005 02:13 AM
