Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
  #13   Ban this user!
Old 06-14-2004, 09:26 PM
Big_Brian's Avatar
Big_Brian is on a distinguished road
Hey Benny if you'd like to try BDI I can send it to you
Is the voice in my head bothering you???
Old 06-14-2004, 10:32 PM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
Thanks Brian for your offer. I have bought a copy of Mach2, so I will stick with that for the moment.
That was a kind offer though.
Old 08-03-2004, 10:34 AM
FLUTE HEAD's Avatar
Gold Member
FLUTE HEAD is on a distinguished road
Well Im also new to emc and have the bdi disks. I installed the redhat and then I booted from the second cd wich is morphix (with the emc program). All I have done is ran it off the cdrom. I saw an option to load morphix to hard drive and successfully did that. A message was posted that the bdi install was complete. I restarted and the computer wouldn't boot. All I saw was "LIL" not Lilo. SO whats next? How do ya restart?
  #16   Ban this user!
Old 08-03-2004, 04:37 PM
Chagrin is on a distinguished road
LILO will write a varying number of characters to the screen during bootup -- each character represents a seperate step in the boot process (kinda). "LIL" means "the descriptor table could not be read".
My guess is that you either have a bad hard disk (not likely) or a larger hard disk (>2GB) on an old computer (with an old BIOS). If you can't seem to get things working after attempting another reinstall, try repartitioning the disk with a small "/boot" partition (64MB should be sufficient) and make this the first partition on the disk (/dev/hda1).
Old 08-03-2004, 04:38 PM
*Registered*
ESjaavik is on a distinguished road
Flute Head, Go to: http://lists.sourceforge.net/lists/listinfo/emc-users
Look through the archives, there may be something there. And join the mailing list.
My guess is that it's a partition problem, and that the Linux partition cannot be reached.
I've only run the Morphix version from CD, but if you made a boot floppy, it will probably boot using that.
New help needed PLZ !! BDI Linux k-linkz LinuxCNC (formerly EMC2) 1 03-18-2005 01:13 AM
