Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 02-19-2007, 09:58 PM
mattinker is on a distinguished road
Thread cutting in EMC
Hi!,
I'm extremely new to CNC and Linux. I have on two occasions come across references to "you can't do threading on EMC", for me, this is one of the principal reasons for going over to CNC, that and acurate taper cutting. Maybe someone can clarify for me.
Thanks in advance, Matthew
Old 02-20-2007, 08:51 AM
samco is on a distinguished road
threading was added recently and is in the latest live cd. 2.1.0. It can be downloaded here http://www.linuxcnc.org/index.php
the manual has a bunch of info on lathe setup
http://www.linuxcnc.org/docs/2.1/EMC2_User_Manual.pdf
Here is a page of what features are going to be add (some have already been- they have a 'done' next to their title)
http://wiki.linuxcnc.org/cgi-bin/emc...anced_Features
Here is a video of cradeks lathe cutting threads (he integreated threading into emc2 - amoung other things )
(right click and save as)
his servo lathe
http://lerneaenhydra.shacknet.nu/ima...readingnew.avi
his stepper lathe
http://timeguy.com/cradek-files/emc/dscn6185.mov
sam
Old 02-23-2007, 03:15 AM
harty is on a distinguished road
hi mattinker
emc 2 will and does cut threads very well i have been using it for a couple of months and cut about 50 threads
you will need an encoder of about 100ppr to put on the spindle and away you go
the guys on the emc irc channel are very helpful
cheers
harty
Old 02-26-2007, 09:05 AM
Ppr?
Harty,
Thanks, I'm very new to all this, also in metric France! What a ppr?
Matthew
Old 02-26-2007, 07:50 PM
unterhaus is on a distinguished road
ppr == pulses per revolution
Old 02-27-2007, 12:57 AM
hi Matthew
as unterhaus said ppr is the number of pulses per revoultion of the encoder for emc you need to have a fairly low resolution encoder 100ppr works great
the higher resolution encoders mean you have to run your lathe at a lower rpm
cheers
harty
Old 02-27-2007, 04:43 AM
Thanks for the replies. I have noticed that a lot of people in the US use abreviations (maybe a text message habit), I!m a Brit! So my language isn't quite the same, when I see things written I have no problems! Sometimes I stare at abreviations (LOL being one of them!) and think what are they talking about!
Thanks again, a pulse counter shouldn't be too hard to sort out.
Matthew
Old 02-27-2007, 01:37 PM
RotarySMP's Avatar
RotarySMP is on a distinguished road
Do you need both a 1/rev signal to index plus a 100/rev to sync to?
This would be required for multiple passes so you always engage at the same place.
The latest Image is the first time I have ever had an EMC BDI or Live work for me. I must have downloaded EMC images 10-15 times over the years, but they never liked any of the miriad of computors I tried them on. This latest Live disk seems to work find on a Compag PIII Laptop I have. I am using TurboCNC on my Lathe, but have been thinking of trying EMC on my mill if I ever get it finished.
Regards,
Mark
www.wrathall.com
Old 02-27-2007, 02:36 PM
does it have to be a low count encoder just because it uses the parport for input? I generally prefer to have a counter, although that costs money.
Old 02-27-2007, 03:12 PM
You can do it without a quadrature but you still need a index pulse.
If you’re using a quadrature encoder and the printer port.
Most people can run a base period of 20us, which is 50khz. Emc2 can count an edge per period. You should be able then to count with a 100ppr-> reading all the edges is 400edges. The max emc should be able to read is 50khz/400edges=125rps=7500rpm. You normally want some headroom though.
If you’re using a non quadrature you should be able to double that.
sam
  #11   Ban this user!
Old 02-27-2007, 06:40 PM
pulse counters
My thread seems to have taken another turn, how about ideas and supliers of pulse counters. How to hook them up etc. I feel sure that it can't be hard, but why not set down some ideas on how to do this. Maybe somebody also has some links on the subject.
Thanks, Matthew
  #12   Ban this user!
Old 02-27-2007, 07:42 PM
I have bought from http://www.usdigital.com/ their parts anyways.
http://www.electronicsam.com/images/...t/Endoder1.JPG
I am planing on buying some from http://web3.automationdirect.com/adc...oders/Encoders
From the specs - it seems that even their light duty shaft encoders have an index pulse. I would have to see it to believe it.
sam
thread cutting FANUC 0i TB xavierdemoura Fanuc 0 09-23-2006 08:07 PM
cutting acme thread barnesy General Metalwork Discussion 6 09-01-2006 09:06 PM
Thread Cutting on MAXIMAT V10 Lathe Kiwi General Metalwork Discussion 1 06-18-2006 12:32 PM
help cutting 6 pitch thread joe1970 General Metalwork Discussion 10 06-08-2006 08:43 PM
Thread cutting with stepper motors? GalaticDan Mini Lathe 1 12-01-2005 01:06 PM
