| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
Can anyone tell me about EMC. I need as much information as you can give me. I also would like to know if this will run in Diablo. I also need to know where to download EMC. Please let me know as much as you can please. I need a control software and I would like try EMC. Thank you for your help keep the information coming. |
| If you have a barebone system, get the BDI-Emc, it is a brain dead install, loads everything for you, all you have to do is modify the INI file to specs of your machine, ie: step direction pins, turns per inch/mm, you can reverse motor direction depending on which side your motors are installed on, and so on, I used the Generic.ini file, and the emc not for the sherline machine. they even have a mirc channel if you need help, it really is simple to setup, and it also comes with a linux cadd program and other cnc software to use. joe |
| Xandros is a successor to Corel LINUX OS that combines Debian and KDE. BDI-EMC is the debian with KDE and other user interface you choose and it will also work in dual boot system, I have it loaded on a Windows xp machine. Emc can be compiled on any linux system as far as i know. |
http://www.linuxcnc.org/index.php?op...emid=4&lang=en joe |
