The answer to your question is on the same document you linked to. Look at heading "6. Calling Files"
In linc you can call an .ngc file from within another .ngc file.
Is it possible to use a variable as a file name so I can use a set of numbered files, starting with 1.ngc goin on for as long as I have files?
I have found this page that does say files names can be numbers but it does not say if those can be added to an if/then loop or something similar:
http://linuxcnc.org/docs/html/gcode/o-code.html
- converting a .sldprt solidworks file into a .stp or parasolid file
- How to make a program that edits .CNC file when a variable changes.
- Need Help!- Converting a pdf file to UG part file
- GPP file, what variable determines rough, semi, finish op when milling?
- converting a mastercam 9 file into a Solidworks file
Sven http://www.cnczone.com/forums/diy-cnc-router-table-machines/320812-aluminium-1250x1250x250-router.html
Yes, I still have some trouble reading technical english every now and then. Have got it woring, thanks!
