Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 09-06-2003, 04:22 PM
anoel's Avatar
anoel is on a distinguished road
Anyone figure out the EMCI.INI
I just setup a Linux box with EMC. To see how it ran the steppers and to see if I liked it well enough to drive my servos later.
I'm finding it quite confusing to get the units set up. It might just be that it's not clicking in my brain.
I've got 200 step per rev steppers. 18TPI lead screws.
Where in the hell do I set up the parameters for these in the INI?
Also, Are the Parallel port Pins defined only one way or can I chage them to be what ever I want? I'd like to set it up to use the Axxus Parallel port card that I have.
Any experienced EMC user input would be Grand. Thanks
Nathan
Old 09-06-2003, 05:45 PM
ullbergm is on a distinguished road
Re: Anyone figure out the EMCI.INI
Originally posted by anoel
[B]I just setup a Linux box with EMC. To see how it ran the steppers and to see if I liked it well enough to drive my servos later.
Look for the INPUT_SCALE and OUTPUT_SCALE variables. I think your value there should be 11.1111111.
I've got 200 step steppers and 20 TPI lead screws. If i had been running it in imperial i'd put in 200/20 = 10.
But since I'm running it in metric i had to do the following:
25.4/20 = 1.27 mm/rev on the screw
which makes my input/output scale: 200/1.27 = 158.48.
let me know if that doesnt make any sense..
i've heard that you can use bridgeportio and redefine the pin outs on anything except the spindle controls.
if you want to redefine the pinouts on the spindles i think you'll have to recompile it (i've heard they are working on making the pinouts options in the config)
When i started with EMC i joined #emc on irc.freenode.net and they were very helpful. they got me going in notime.
Old 09-23-2006, 02:43 AM
abfa9358 is on a distinguished road
Imperial
20 tpi
200 steps / rev
input scale 20x200 =4000
i.e. 4000 steps per unit(inch) of travel
output scale relates to servos
Power Supply moto21 Xylotex 10 02-20-2005 02:50 PM
Help Me Figure the Specs of My Motor. cbcnc Stepper Motors and Drives 3 08-14-2004 11:21 AM
How to figure needed stepper motor size? Hack General Electronics Discussion 4 07-19-2004 04:43 PM
How to figure out what servo size you need replicapro Servo Motors and Drives 8 06-24-2004 06:45 AM
how can i figure the tpi of a lead screw? ljoe1969 DIY-CNC Router Table Machines 1 01-07-2004 10:25 PM
