Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 02-02-2012, 05:15 AM
bebob1 is on a distinguished road
How to setup stepper motor as spindle?
I am completely new to EMC2 so I have no clue what I am doing yet.
I understand so far that steoconf, the simplfied wizard, cannot setup stepper spindles?
How do I go about doing this? I read something about changing hal, but its not very precise and I am not sure where to start.
Essentially I want to occasionally mount a stepper to drive the spindle of the lathe instead of a DC motor from time to time, so as to allow me to do threads correctly without retrofitting an encoder since I have no parport pins to input that data for EMC2 to read the actual spindle speed.
Old 02-02-2012, 06:16 AM
svenakela is on a distinguished road
Hmm... How come your parport is full, on a lathe?
A stepper conversion sounds way more time consuming than an indexing encoder setup.
Old 02-02-2012, 08:28 AM
cyclestart is on a distinguished road
Have you ruled out single pulse threading ? Adding a stepper also takes up pins ?
I haven't tried this myself so can't offer a how-to but it is the next mod for my 4th axis (currently only a spinner)
Anyone who says "It only goes together one way" has no imagination.
Old 02-02-2012, 01:14 PM
I dont mean to say it is full technically. But I have no other way of accessing the unused pins since I dont have a breakout board and the parallel port cable connects direct from computer to commercial driver. No breakout board in between. The drive takes up 4 axis driving but there is technically some unused pins.
Short of this, I thought an easy way for me is to just swap steppers from mill to lathe. However I since lathe motion only requires 2 steppers and I have a spare, so might as well pop that into the mix as a spindle from time to time to allow for threading.
Question is how to set up HAL to do it? complete noob at it.
Old 02-02-2012, 09:02 PM
This could be done by using a 3 axis configuration and some G01 moves. Think of the spindle stepper as another linear axis and proceed as if cutting an angle in a 2D plane. A thread is really a ramp that happens to go around a cylinder. It's not an elegant solution but it's probably the caveman way I'd approach it. (also because I don't have a clue how else to do it )
Look near the bottom of the page in this link:
Projects 5
if my memory is working properly that's the method used to cut those threads
just tossing out a possible, and possibly ugly, alternative.
Old 02-03-2012, 06:46 AM
Faulty memory, he did program as A axis.
Gcode can be found in this post:
http://www.cnczone.com/forums/307081-post173.html
Treating as linear moves would also work, pretty sure.
The hot set-up would be a servo motor but more $$$$ and complexity.
Hope you find the answer to the original question.
Old 02-05-2012, 01:07 PM
chester88 is on a distinguished road
Here is a thread on the subject in the linuxcnc forum:
Configuring a stepper as spindle motor - LinuxCNC Support Forum
you will need to hand edit the config files.
it involves connecting a step generator component which is in _velocity_ mode to the parport and to linuxcnc's spindle speed control.
No idea how to setup the stepper motor Syphonics Stepper Motors and Drives 12 03-06-2007 08:43 AM
Dual stepper motor setup Goose80 Stepper Motors and Drives 7 12-19-2006 11:46 PM
Inexpensive Closed-loop Stepper Motor Setup? lazlo Stepper Motors and Drives 4 04-18-2005 09:53 AM
