Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 01-30-2012, 10:23 PM
docltf is on a distinguished road
adding 2nd pport
going to try emc2.
I will need to configure a second pport.the auto config only works port 1,but doesn't do port 2.can some one post their hal ini with a second port configured.i need a pattern to follow for the syntax. I have my port address's,but real confused what and how to edit.A 2 printer port hal to use as a map would be nice.
thanks,Bill
Old 01-31-2012, 03:17 AM
svenakela is on a distinguished road
Hi Bill,
Unfortunately I don't have a config available, but read the following thread. I think you can get some good info in some of the replies.
[Emc-users] Installing a second parallel port
Regards,
Sven
Old 01-31-2012, 08:52 AM
Sven
thanks for the link,it has a few things but adds more questions.they give functions to use in a file but not where in the file.there are examples of syntax in one post and three post later they post a correction to the syntax.the port address's i have but config for two files is sketchy.a working ini for a 2 port to use as a map would really help.
bill
Old 01-31-2012, 03:38 PM
Are you adding an extra par port for a pendant or a fourth axis?
LinuxCNC Documentation Wiki: Hooking Up A MPG Pendant
MPG2 Jog Pendant | chembal.com
Old 01-31-2012, 04:22 PM
Sven
I am adding 4Th rotary and 5Th linear.
I have port 0 and 1 recognized.
just cant wrap my head around the config in both ini files for the syntax.
also i have to get the 5th dro up on the screen.
if i type in a 5Th in both files where does it go.
every thing that i read has conflicts,set the port in,set the port out, don't set the port etc:etc:ha,ha
bill
Old 02-01-2012, 02:45 AM
Join the mailing list or the IRC and describe what you need. You'll find help there.
Need Help!- Adding Another PP M250cnc LinuxCNC (formerly EMC2) 16 07-28-2010 07:47 PM
Need Help!- Adding an X axis power feed to my smithy 1220XL milling table.Adding an X axis power matridium Smithy 0 05-28-2008 10:37 AM
Adding a fan to the X3 Antonyong Benchtop Machines 2 04-25-2007 11:19 PM
Adding a 4th Shizzlemah Fadal 5 12-01-2005 05:16 PM
Buffers for PPort! Info! vacpress General Electronics Discussion 1 03-16-2004 06:40 PM
